It is currently Wed Aug 06, 2025 6:11 pm
PostPosted: Thu Feb 23, 2012 9:09 am
Sounds like a myth to me.
I'd bet the small difference if anything the paint makes, would be lost again by the radiator having higher wind resistance. :lol:
PostPosted: Thu Feb 23, 2012 9:11 am
AJ wrote:
Has anyone painted one of these black ? It would be interesing to see how much difference it makes to the cooling ,as the black is meant to absorb more heat from the circulating coolant,whereby it can then be taken away by the action of the airflow through the fins
In this case it is fluid contact not light so it is really dependant on the ability of the metal to absorb the heat and transfer that heat to the airflow going past. It could probably be purple and make no difference. Happy to be proved wrong though... cant see myself with a purple radiator :D
Alec
PostPosted: Thu Feb 23, 2012 9:26 am
painting the radiator would insulate the aluminium, and make it keep more heat inside - you want to make sure the paint is heat conductive, engine paint would be OK, but I wouldn't do it...
the aluminium absorbs the heat from the water, black paint might help radiate more heat away from the radiator, but the difference would be minimal
PostPosted: Thu Feb 23, 2012 9:29 am
You would definitely want to run coolant in these, not plain water- even so I'd be worried about corrosion long term.
I used to own an EA Falcon.... :roll: their 2 core POS alloy radiators clogged big time. A 3 core copper/brass taxi special one fixed it. 8)
PostPosted: Thu Feb 23, 2012 7:07 pm
Was just wondering about the aluminium, because I used to have a radiator sales and repair business back in the 1980's,and we didn't see too many aluminium radiators back then,and all the radiators were spray painted black with some el cheapo paint we got from the radiator core suppliers, many of the cores even came already painted. The older car radiators are made of plated brass,with copper used for the cooling fins,with some of the larger industrial ones using copper tubes and even steel . Copper has better heat transfer properties than aluminium,but I guess aluminium is cheaper these days
PostPosted: Thu Feb 23, 2012 7:19 pm
I wonder if the paint was more about stopping radiators turning green than anything to do with radiating heat.
PostPosted: Thu Feb 23, 2012 7:20 pm
Yes I think that was the main reason ,to protect the metal from discolouring and corrosion which would reduce the heat transfer properties
PostPosted: Thu Feb 23, 2012 7:31 pm
The paint helps the heat transfer from the metal to the air.
I have one of Phil Irving's books where he lists the difference in heat loss between rough cast aluminium, polished aluminium and matt black painted aluminium.
It works even better if you paint the inside! :lol:
I remember an experiment on TV years ago, I think it may have been Julius Sumner Miller, where they painted one milk bottle black and another milk bottle white and filled them both with boiling water and then placed a thermometer in each one. The black bottle cooled down much quicker.
PostPosted: Thu Feb 23, 2012 7:38 pm
I believe it was Phil Irving who discovered that a thin coat of black on engine and gearboxes of motorbikes reduced oil temperature.
Black apparently both absorbs and radiates heat better then any other colour.
However, I would imagine some paints especially if applied thick would act more like an insulator.
All of the above was learn't via motorcycle magazines so it could be total........
You beat me to it Morris :lol:
PostPosted: Thu Feb 23, 2012 7:39 pm
Ahh why is it so
PostPosted: Thu Feb 23, 2012 7:46 pm
So back to my original querie , do you think it would help much with an aluminium radiator,a type which I haven't had much experince with
PostPosted: Thu Feb 23, 2012 7:50 pm
I think it would help, the easiest way to find out is to test one along the lines of the milk bottle test.
PostPosted: Thu Feb 23, 2012 7:54 pm
Hmm...... may have to buy 2 and paint one black :D
PostPosted: Thu Feb 23, 2012 7:58 pm
If it doesn't work stick it on ebay. :lol:
Users browsing this forum: IndigoBlueCooperS and 84 guests
