@ Michael
I have the larger Rover Disc brakes they are 8.4"
I am not sure what bearings were put in and the bearing that was replaced is making a slight clicking sound when i do right hand corners :/
The rack was fixed the first time as there was lots of play either side of 12 o clock position.
I do like what they have on there now but driving it every day and hearing the croaks in the front that have come along since i put the 13"s from 12" on is a little worrying.. I will keep the 13" and whip them out every once and a while.
@Harley
I don't mind changing bearings every couple of years i would back go down to 12"s but i have not found one in the design i like so ill give 10's a go.
I do like the handling the 10" give you and you have a bit more of a cushion from road noise and such.
@Convertible mini
I do like the white but i am not really a fan of that design
@fiji
Bearings cost $200 per side and to fix the rack i was charged $60 and its been going well for 2 months
I don't mind converting the discs and getting the new tyres but i don't want to get rid of the arches as there are holes drilled through the body and its to much of a hassle to plug the holes and re spray all the effected panels.
I would like to see how 10" look on the Rover sport pack arches which were designed for 13x6
@Mike
I might take you up on that offer, Did you do the disc conversion your self or pay someone else to? I am thinking of attempting it
Looks a little off putting :/
But then this looks good.
Thanks for the forum link mike. I will have a read of the comments.
I think i will have to play around with lowering either end.
I have hilos in the back but i am thinking of putting them in the front.. I assume as i own a Rover it will take me twice as long to convert the front?
@mini mad
1. Is that the Dr mini that has posted above you? If so i will PM him about it
2. Do you know how long it takes to fit a steering rack?
3. Current wheels have an offset of ET-7 and the new 10" ones i am looking at getting have ET-7 Offset..
http://tinyurl.com/6vuy4aw is a link to the ones i am looking at
4. After reading Mikes post with the forum link I am thinking ill go ahead with it and hang onto them for a month and flogging them off. Someone has already pm'ed me and i have not put them for sale yet
they are only 3 months old.
5. My car had 12" minlites on and they were fantastic compared to the 13"
6. I would like the handling back on them.
Does anyone know the difference with ET-3
Thanks for your suggestions and help guys!
