It is currently Sun Jul 27, 2025 4:13 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat May 28, 2005 9:44 pm
meeni wrote:
just adding to it, you can accelarate for the first time no probs, then if u let the throttle off and put it back on again it misses big time, it threw flames before!!!!
make sure your dashpot has oil in it.
PostPosted: Sat May 28, 2005 10:44 pm
:lol:
PostPosted: Sun May 29, 2005 6:28 pm
i did everything today, the carbies have oil im not an idiot, and it runs like crap!
Potato
PostPosted: Mon May 30, 2005 7:56 am
In the "never assume anything league" -
You've also got a post about wiring up a tacho - you haven't stated playing around with the wiring have you?
I short in the tacho can also cause some running issues.
PostPosted: Mon May 30, 2005 10:07 pm
teh admin God
teh admin God
big willy wrote:
WTC mate??
:lol: :lol: :lol: :lol:
good one :wink:
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Tue May 31, 2005 11:26 am
hmm, the tacho isnt on there, it runs crap it is in tune, because it is good untill you whack it in first then it bogs down and can barly get up my driveway, as for the driving..... i didnt say i had been on the road lately!!!, so i reackon the cylinder head may be stuffed, cos it has nothing!
Potato
PostPosted: Tue May 31, 2005 11:40 am
Are you sure it's the cylinder head or something in your head!!!
Pete
PostPosted: Tue May 31, 2005 11:45 am
meeni wrote:
It runs crap it is in tune
...that's an oxymoron if i ever saw one!
PostPosted: Tue May 31, 2005 11:46 am
im not sure, but i know its not normal for an 1100 with twin s.us to not get up a mediumly steap driveway, it took 3 tries!!! weve got no idea what it is!
Potato
PostPosted: Tue May 31, 2005 11:50 am
gee i love this forum if you havnt got anything helpful to tell me fiddle sticks off to a different section, im trying to learn but im not being helped by many people, credit to some who have, thankyou but the rest of this has been pure crap, this thread could have been 3 replies long, and i wouldnt of cared cos i wouldnt of had people calling me stupid wen im not, if you think ur so good, tell me what the problem is, dont carry on about me being too young, get over it!!!
Potato
PostPosted: Tue May 31, 2005 11:52 am
my advice is you use your ears (eyes).....
listen to (read) what we are saying (typing)....
get someone to do it for you :?
PostPosted: Tue May 31, 2005 12:31 pm
From what I can make out it sounds like it's dying under load, the cause could be many things including but not limited to: Fouled plugs, faulty leads, bad fuel, blocked fuel filter, blocked jets blown head gasket etc. start by pulling the plugs and checking /cleaning them then check your leads by pulling them off one at a time while the engine is running and listen for the change in revs or if they're old just change them anyway.
Check all those things 1 at a time then post here with the results, without knowing exactly what you've checked it makes it near impossible for anyone here to offer a possible sollution.
PostPosted: Tue May 31, 2005 12:54 pm
meeni wrote:
gee i love this forum if you havnt got anything helpful to tell me **** off to a different section, im trying to learn but im not being helped by many people, credit to some who have, thankyou but the rest of this has been pure crap, this thread could have been 3 replies long, and i wouldnt of cared cos i wouldnt of had people calling me stupid wen im not, if you think ur so good, tell me what the problem is, dont carry on about me being too young, get over it!!!
we can't tell you what the problem is, the only thing we can do is make a few suggestions, we've tried before - what Wolfman is saying is that it could be just about anything, or it could be a lot of things together all contributing to the problem. In your stalling thread, I suggested you take it to a mini place and get it tuned, take it to anyone and get it tuned.
Or, be nice to John Small and ask him to come and have a go at it for you, he lives nearby doesn't he? it's really really hard to diagnose a problem like this without specific details of what's set, or being infront of the car and actually working on it.
I could say that you have it very rich, as flames out the exhaust would suggest. What I would do in that case is reset the carb mixtures - read Makka's post. What the book says to do is take the dashpost off, and turn the mixture nut up till the jets are inline with the 'bridge' in the carb, then put the dashpots back on, make sure that the pistons actually fall all the way down, don't get stuck half way etc. Then lift the each piston with your finger and let it go, there should be a dull metallic thunk, if not, then the needle is out of alignment, fix that first. Next, turn the adjusting nuts down 2 complete turns. Then start the engine and set a fairly fast idle on each carb, by listening down the mouth of each carb through a rubber tube, get them to sound the same - sucking the same amount of air. Next thing to do is do the adjusting nuts up 1/4 of a turn each until the idle just starts to slow down, it should be at the lean point. There is a button under the dashpot on each carb that you can push up, push it slowly and it lifts the piston. Do it for each carb, if the engine dies down, then the mixture is too lean, if it picks up, then it's rich. Ideally, the engine should pick up slightly then settle back to the same idle. When you're done, adjust the idle speed to a nice idle, again making sure the carbs are sucking the same amount of air by listening with a rubber tube
that's the best advice I can give you on tuning twin carbs. And it's assuming that your distributor timing is correct
PostPosted: Tue May 31, 2005 2:01 pm
haha dude, get over it, i love how i get the reaction :lol: you bring it on yourself, look at half the replies here, alot have been helpful and alot of the time if someone posts something to help you out you come back with "i'm not an idiot! of course i did" or something similar...
first of all, who called you an idiot? no one..we're just suggesting what it could be, i think you bring yourself into believing that behind your back we're calling you these things...
We have no idea what you've tried, your skills (ok, by the way you post we have a rought idea :D), and this is a public forum so i'm not going to "****" off (and really swearing AT someone? we're going to really warm to you now) we can suggest what we like, and hell it may even help someone else who has the same problem down the line...
continue...:mrgreen:
PostPosted: Tue May 31, 2005 2:17 pm
fiddle sticks off minimad
:lol:
Users browsing this forum: No registered users and 72 guests
