It is currently Sat Aug 16, 2025 1:53 pm
PostPosted: Tue May 22, 2012 8:36 am
Check if your insurance covers you for a new screen without an excess. You may be pleasantly surprised. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue May 22, 2012 6:08 pm
I just put an old laminated screen in my bin and it took a lot of hitting with a BFH to make it fit. And I was not able to smash a hole in the glass so I would therefore assume a head would find it very hard :shock:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue May 22, 2012 8:39 pm
That's why I've taken to wearing a clay bar on my head. In the Traveller there are no seatbelts, so I reason that the clay bar will burst the windscreen before my head reaches it. :lol:
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed May 23, 2012 1:36 pm
if the clay bar is really a brick yer that will do it ..
PostPosted: Wed May 23, 2012 3:40 pm
I could have got it to fit in your wheelie bin no problem. I'm pretty skilled at breaking windscreens when gently trying to fit them to a car, so fitting them in a wheelie bin with a BFH is easy :wink:
PostPosted: Thu May 24, 2012 8:58 pm
LOL. Clown! love it.
anyone know how to tell what screen i've got before attempting a polish?
PostPosted: Thu May 24, 2012 9:08 pm
WOODWORMM.
It should have a stamp on the glass. Triplex or Laminated, or Toughened or safety glass.
If its got a tint band at the top it's probably laminated.
Other test is a pair of polaroid sun glasses. In the sunlight Laminated shows a pattern in the glass.
Alex.
PostPosted: Fri May 25, 2012 11:02 pm
What does people use to clean windows... Thinner????
PostPosted: Fri May 25, 2012 11:12 pm
Thinners and a razorblade
Metho and newspaper
Windex and paper towel!
In order of effectiveness
You're so square
Baby I don't care
PostPosted: Sat May 26, 2012 11:05 pm
coopar wrote:
Were you throwing the clay bar at the windscreen?
I lol'd irl
PostPosted: Sun May 27, 2012 12:01 pm
metho and a razor, if that dont work i use cerium oxide powder and a polish wheel
PostPosted: Sun May 27, 2012 3:37 pm
That's fine on a Triplex (laminated) screen, I got warned off polishing a toughened (old Mini) screen.. for the reasons I stated at top of this thread. Tinkle tinkle... :P
PostPosted: Wed Jun 06, 2012 2:48 pm
Sent the following to Meguiars.
Dear Sir / Madam,
I regularly read posts made on the website: http://www.fordforums.com.au where I was introduced to your Quik Clay product. There were a lot of positive reports on the product. Back in 2010 I bought one of your Quick Clay kits for use on my classic Mini. As reported on the web site I was very happy with the results on my paintwork. There were numerous reports about using the product on their windscreens to get them really clear. I used Meguiars Quik Clay on my windscreen following the instructions given. That day when I drove my Mini the windscreen shattered. I put a post up on the website asking if anyone else had experienced the same thing. I was told no, they have been using it for ages on their windscreens with no negative results. This past weekend I was preparing my Mini for a classic car show and thought maybe it was a coincidence so I used Meguiars Quik Clay on my windscreen again. Once again the results were good and my screen was very clear, but once again the first time I drove my car the windscreen shattered. After some research I found the following examination to why my screen shattered:
● Its because it is a toughened (not laminated) screen. Used on all Australian Minis except Cooper S (and maybe the GT) which were laminated. The surface of the glass is in compression, when you clay bar it the surface stress is released, so tinkle tinkle. You shouldn’t even polish marks out of these screens with glass polish I’ve been told.
Get a new laminated screen……
As there is no mention of any problems associated with the use of Meguiars Quik Clay on glass on the product packaging. It opened up a debate on the website about cars with laminated windscreens and toughened glass side windows, please see the following posts:
● It has to do with the surface tension of the toughened glass. Because the glass is baked again after cutting and shaping the surface shrinks thus compressing the internal structure of the glass and hardening it. When you clay bar it you essentially are polishing the surface at a molecular level creating an uneven hardened surface. The compressed glass under the hard surface coat just needs the smallest weakness in the surface tension to cause it to fail and all it would need would be something as insignificant as a sudden temperature change or even a decent bug splatter at 100kph to "pop" the windscreen.
● Modern technology and toughening techniques have all but eliminated the issues experienced with old school toughened glass. It used to be that glass was suspended from pincers and sent back into an oven and the heating process could be a bit variable in it's results. If you check the old toughened glass from the 60s' and 70s' you'll see small dimple or pin ning nong marks along one edge where it was gripped by the pincers. Modern techniques don't hang the glass the same way and the heating process is a lot more even and controlled which makes the glass even tougher which is why a new side window can be 3mm or thinner and still hold integrity where as back in the 70s' and before the glass had to be at least 4mm thick to survive. Clay barring modern auto glass is not a problem as the surface of the glass is harder than it used to be and is mostly unaffected but that wasn't the case 30-40 years ago. Also, the larger the surface area and the more curvature to the glass, the more stress the surface is under and the more vulnerable it is to popping due to irregularities. Rule of thumb is, don't try to polish a 40 year old toughened windscreen, they don't like it.
I don’t know if you have heard of any other case where this may have happened or were aware of the possibility, but after purchasing two new windscreens for my car I think your product should carry a warning about using on any glass on any vehicle manufactured before the creation of the more modern glass. Fortunately for me, apart from a few minor cuts picking glass chards up and punching a hole through my windscreen while driving to see where I was going I was not badly hurt, but as soon as the windscreen shatters obviously I couldn’t see where I was going so the situation could have ended quite differently.
As explained this did open up quite a debate on the website mentioned with some people concerned about the use of the product on glass. I have posted on the site that I will be contacting Meguiars and that I will post any response that may be received.
Regards,
This is the responce:
Would anyone know who the windscreen manufacterer might have been? Pilkington maybe?
PostPosted: Sat Nov 03, 2012 10:11 pm
Sorry to bring this one back to the forefront again but I found something that may be of interest. I recently discovered the 'Bowdens Own' range of car care products and was reading through their website when I found this article on windscreen cleaning and polishing. If you look at their car collection and their reasons for creating their products its hard to imagine that they would risk any of their near priceless cars. http://www.bowdensown.com.au/glass-polishing-secrets
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Sun Nov 04, 2012 12:46 pm
Muhahahha absolute gold ..
And urrrmm whats this using a clay bar to use a windscreen ? i guess im missing something as ive never heard of it ? is it an actual clay bar or just a product name ?.
If our windows get really dirty we just use vinegar in water and clean with a newspaper " parents old school way " .
Users browsing this forum: No registered users and 349 guests
