It is currently Sun Jul 20, 2025 12:30 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 29, 2012 11:31 pm
Thanks again.
When I first installed the master cylinder a few months ago I forgot I ordered the gaskets which sit under each master cylinder. I had to put on a new base plate as the old one had a larger hole for the engine steady.
When I put in the second kit I put the gaskets on but did not tighten it down enough on the back bolt.
After partially bleeding the system I got my brother to push the pedal and saw the movement in the back bolt. Some smarty had replaced the 1/2 inch bolt with a 12 mm one so I had to use two different spanners to get it down tight.
I will try the bleed again this weekend and work out whether to replace the master and the slave cylinders and probably go and see John Schmidt next Monday.
Users browsing this forum: crisonic and 68 guests
