It is currently Tue Jul 29, 2025 6:39 am
 Post subject: Speedo cable.
PostPosted: Fri Jun 29, 2012 9:34 pm
Verrrryyyy easy on the hoist.
"Let us remove your "SHORTS"
PostPosted: Fri Jun 29, 2012 10:06 pm
I done one for a mate a couple of weeks ago , i removed the ( top ) , of the bottom radiator hose , ( Off the water pump ) , and you can get your arm down there without too much trouble .
The worst part is trying to get the nut off the gearbox end if they haven't been touched in a long time , a small pair of multi-grips work well .
Once you have got the nut off , give the thread on the gearbox a good clean , and put a
light smaer of grease or Vasoline on the thread , then only do the nut up finger tight .
Also , another trick i do is , put some tape ( or a cable tie ) around the cable at the top ,
so the top nut can;t run back down the cable , whilst you're trying to get the bottom nut sorted .
PostPosted: Sat Jun 30, 2012 10:35 am
Another trick is to get the longer Morris 1100 cable. Doesn't make it any easier to get your hand in but it's less of a pain to get it to mate up again.
PostPosted: Sat Jun 30, 2012 12:17 pm
I always fit a cable tie to the top of the cable, it saves a lot of frustration in most cars especially Morris 1100s.
PostPosted: Sat Jun 30, 2012 1:46 pm
I think the best advice would be to just have a crack at it. :wink:
Some find it easy, some find it hard. You'll never know if you don't give it a go.
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Sat Jun 30, 2012 1:50 pm
Do you have a child?
Surely they've always wanted to help work on the car, maybe it's time ot get them involved :wink:
You're so square
Baby I don't care
PostPosted: Sat Jun 30, 2012 3:11 pm
Tried that. Keen to help but not the least but helpful.
