It is currently Thu Aug 07, 2025 3:56 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Sat Aug 04, 2012 11:54 am
A clue for dating these cars, they made just over 60000 of them over a five year period.
5 years = 60 months. So they produced an average of 1000 cars a month.
But they made more cars a month in the the first four years and it slowed down in the last year (after the release of the Mini Deluxe in March 65)
But as a rule of thumb the 1000 a month is a pretty good guide.
So when did production of 850's cease ? mine is car 56562 ,so would that be 1966 ?
PostPosted: Sat Aug 04, 2012 1:46 pm
Production ended in January 66. So you could subtract at least 4 months off that for your car. (at a rough guess)
PostPosted: Mon Aug 06, 2012 1:57 pm
Location: MinisintheGong [Somewhere on the South Coast]
My 1961 Aus made 850 may not be??? Can anyone help?
It has 4538 stamped in the firewall and the same under the driver's seat in the floor pan. It had a ID plate on the firewall on the passenger's side, and five digits under the plate as seen by the two holes and the patina. I have some paperwork indicating its YMA2S1 71505 / 4538
The numbers under the [removed] plate are hard to read fm the photo I have but appears to be like 33821
This car has slotted drains at the front, and twin holes at the rear in the guttering.
It had the strangest and extra heavy seats ~ now gone, and those early seat brackets welded to the cross beam. Black plastic kick panels on the front of the doors. Small door handles. I cannot go out and look at it considering its over the hill on a mate's property. Therefore, I'm working on photos.
I'd appreicate any assistance from the 850 experts. Thanks :?:
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
PostPosted: Mon Aug 06, 2012 2:09 pm
It certainly sounds like an early one.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Aug 06, 2012 3:01 pm
Sounds just like my early `61 850 but it's not- 3 weeks after I sold it, that one met a sticky end. :cry:
PostPosted: Mon Aug 06, 2012 8:50 pm
I have just received the book "Making Cars in Australia" which is the story of BMC Zetland. If gives a breakdown of new vehicle registrations based on data from the Federal Chamber of Automotive Industries.
The number of new Minis registered over the years of the 850 was
1961 = 5426
1962 = 14424 (850 and Cooper)
1963 = 20913 (850 and Cooper)
1964 = 16631 (850 and Cooper)
1965 = 15193 (850, Cooper, Deluxe and Cooper S)
1966 = 13248 (850, Deluxe and Cooper S)
So the only year you can get a really clear look at is 1961. You can work the others out roughly with other data but 61 is easy.
So car 4538 is roughly September 61.
 Post subject: 850 ID
PostPosted: Mon Aug 06, 2012 11:00 pm
Thanks Morry that's great for the confirmation.
I've seen many cars but never one with the same firewall number stamped identically on the floor. Has anyone seen this before?
And has anyone seen the ID plate on the passenger side of the firewall?
Wayne
PostPosted: Tue Aug 07, 2012 6:44 pm
Early 850s had the ID plate on the passenger side. Not sure when it changed, but car 12178 is still on passenger.
Car 5173 has the body number on the floor behind driver seat, Car 10131 behind passenger seat.
Evan.
Saxon Green 850: http://www.ausmini.com/forums/viewtopic.php?t=62641
Nightfire Red 850: http://www.ausmini.com/forums/viewtopic.php?t=66555
PostPosted: Tue Aug 07, 2012 8:58 pm
With your Car being 4538. When you are over the hill next, can you please check to see if it has or has not got a fresh air vent hole?. Which will help us narrow down example one at the start of this post. You may be able to check on a few that we are about to put on!!
 Post subject: 850 history
PostPosted: Tue Aug 07, 2012 9:11 pm
Back to the start of the Post..We will try a few more.....
We have bent sunviser brackets on Car 9229
We have straight one's on 18631
Diamond pattern roof lining on Car 8238
2 squares and 2 dots on the roof lining Car 18631
Internal light on the left hand side behind passengers head Car 756
In the centre of the cars roof linings. Car 2874
 Post subject: Vent hole
PostPosted: Tue Aug 07, 2012 10:36 pm
No worries Flapper
I have looked at photos. my Cooper S has a (approx) 100mm vent hole with a cover on the firewall on the drivers side but the 850 has nothing. Certainly no vent hole in the firewall - only the speedo (rotisserie) hole.
Is that what you were after?
Hope it helps.
