womble99 wrote:
So I guess that begs the question, is it worth replacing the donuts? I am in the process of working out what I need to do to restore mine so I am keeping an eye out for items which are rated for replacement. The dollars only go so far.............
CJ
You mentioned replacing shocks and seats to get the suspension up to par.
Replacing the shocks won't do much for the poor suspension. It's the donuts you need to see to.
It's a reasonable size job, but doable at home.
I'm sure someone on here would be happy to come around and help you do it it.
The rears are easy to do.
The fronts are easy enough to do out of the car, a lot harder to do in the car, but doable.
I would be looking into one of the kits that Minisport/Minispares/Huddersfield do. Comes with Hi-Lo's (so you can wind the car up and down for more/less ground clearance), new shocks, and most importantly, new donuts.
There really aren't that expensive, it's the shipping that will get you.
Also, a few other things:
A Morris 1100 is a different car all together. Same power unit, it's basically a mini, but slightly larger, and much more comfortable.
Doesn't ahve any of the good looks, and doesn't handle quite as well, but it's close!
Link
A landcrab, is the bigger version of a morris 1100.
Similar body style, just bigger.
Link
