It is currently Tue Aug 05, 2025 9:35 pm
PostPosted: Thu Dec 06, 2012 8:19 pm
anyone have ideas on where to get a spacer or what to use?
PostPosted: Fri Dec 07, 2012 12:46 am
I have a late clubby so it might be different but arent the reels mounted inside the rear bins out of the way?
Alec
PostPosted: Fri Dec 07, 2012 8:29 pm
That's only on the later Clubbies, not early ones or roundies.
@ womble99,
the bolts, spacers and washers should be available from people that sell seatbelts, or fit them.
Try Repco, or your local parts & accessories purveyor.
Or, an authorised seatbelt fitting station- if they have these in your state like NSW does.
PostPosted: Sat Dec 08, 2012 7:08 am
The Mini King
If You Pm Me with your Details I wiil post You some new old stock spacers and a selection of bolts
PostPosted: Sat Dec 08, 2012 1:57 pm
Cheers John, pm sent
PostPosted: Tue Jan 08, 2013 4:47 pm
Hey John, did you get my pm? I sent a couple to other people and they didn't seem to get through either?
cheers,
CJ
PostPosted: Tue Jan 08, 2013 5:12 pm
how much effort would it be to convert static belts in a roundy to bin mounted retractables? re-inforced mounts? some sort of inspection / approval required?
PostPosted: Tue Jan 08, 2013 6:22 pm
It depends on how legal you want them :shock: If you can put them in the original location you are good to go, place them anywhere else then by rights you should have them engineered.
CJ
PostPosted: Tue Jan 08, 2013 6:37 pm
The Mini King
cheers,
CJ
No Sorry, Try My email [email protected]
Still happy to help if I can
PostPosted: Tue Jan 08, 2013 8:03 pm
John Smidt wrote:
cheers,
CJ
Thanks John, email on its way
