It is currently Wed Jul 23, 2025 11:07 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 21, 2013 8:51 pm
Kennomini wrote:
On a side note; I have a 1100S block already bored 0.030thou (1310 correct?)
1301cc
Kennomini wrote:
I'm planning on re-boring it and installing 0.095thou (1360) I should make sure they move 1 and 4 towards the outer ends of the block 0.030" each Correct :?:
:EDIT:
Is offset boring the same as stagger boring :?: I always though stagger boring was something like 1 & 3 move forwards (towards the dizzy) and 2 & 4 move backwards (towards the exhaust) :? :?:
the idea is to make the spacing between 2/3 the same as between 1/2 & 3/4, so move 1 & 2 0.015" towards the water pump, and 3 & 4 0.015" towards the oil pump. Spacing between 1/2 and 3/4 stays the same, but the spacing between 2&3 grows by 0.030"
PostPosted: Thu Mar 21, 2013 8:52 pm
MiniVLT wrote:
Std oversizes are .020" is 1293 & .040" 1310 & .060" is 1330, so i'm guessing .030" is 1300. .030" sounds like an odd oversize???
Cheers Shane
Original BMC oversizes were +.010, +.020, +.030 and +.040.
030 is still common for V8s etc not so common form Minis but yes this size is still available from some suppliers.
@kenno-
Nope most Mini head gaskets are made this size to allow big rebores.
Nope if doing it you need to move all 4 bores, 1 & 2 go .015" towards the radiator and 3 & 4 go .015" towards the clutch.
This makes the gap 2-3 the same as the other two.
If only going to 1360 it's not essential though. Both my 1360 and 1412 stroker have the standard spacing still.
PostPosted: Thu Mar 21, 2013 8:54 pm
Cheers Shane
1303cc actually
but it was pretty common back in the day, just not so much anymore
PostPosted: Thu Mar 21, 2013 9:29 pm
at 1380, without offset boring, the wall between 2 & 3 is 2.69mm, if offset bored, it's 3.45mm... 2.69mm is pretty thin
PostPosted: Thu Mar 21, 2013 9:36 pm
I agree. It is good to offset bore when you go to 1360, but this is easier with some borers than others...
PostPosted: Thu Mar 21, 2013 9:38 pm
we offset any/every block whenever we have to bore them,,, even if it`s only a bit then it makes it closer to the mark for next time it gets bored
just common sense really
both of my 1510cc blocks moved 15thou out for the inner cyls & 25thou out for the outer cyls
some break through to the oil gallerys on the end of the block so we just plug em up with a mild steel rod lockited & punched in & then just offset drill em,,, clean up the protruding plugs inside the bottom of number 4 bore with a die grinder & you`re done
easy-peasy & we`ve been doin it this way forever,,, since about 5 million years ago :-)
PostPosted: Thu Mar 21, 2013 10:04 pm
it is common sense - I've only just found a machine shop that can do it, my usual bloke's machine can't do it so I've been sticking to 1330's.
I'm running out of blocks, and it seems that the entire world is out of +.040 and +.060 Hypatecs.... my last spare block is standard bore, so I could go .020", but I wanted offset that from the start by going to .040
I can get my current +.060" taken to +.114" with 0.012 on one side and 0.042 on the other... going to .094 only gives .002 so wouldn't give a lot of room for error to my machining man
what do you reckon?
existing .060 out to .114 with .015 offset
or
standard out to .020 and offset it next time? (even .005 offset only gives machining man .005 to play with)
PostPosted: Thu Mar 21, 2013 11:40 pm
Excuse my ignorance - having a deadhead moment!
So if we offset the bore in the example simon and kev used the bore grows 15thous towards one end and 5 thous towards the other- instead of 10 /10. (yes???)
what has to happen to accommodate this shift in centres- rods/crank please.
Cheers Darryl
PostPosted: Fri Mar 22, 2013 6:46 am
Oh dear, worry, worry...
HI Simon
I have 72.5 mm pistons which is .070 over size to give the blocks one more bore size.
Graham Russell
PostPosted: Fri Mar 22, 2013 7:10 am
Cheers Darryl
The rods have about .030"? each way side clearance to the piston bosses- so the pistons will just move sideways .015" or so.
You need to eyeball them after assembly but clearances are usually OK.
 Post subject: Over bores and Offset
PostPosted: Fri Mar 22, 2013 7:26 am
I have been fitting Mazda poisons to My Mini Engines since the early 80. It started as an experiment when building a stroker engine because of their deck height. I have built them using 73, 73.5 ,74, and even 74.5. I always got my boring done according to the specs on the David Vizard Book. Never had any problems using the Metro Turbo Head gasket which had larger diameter firing rings and has re enforcement between 2 & 3 cylinders where the engine runs the hottest as there are two exhaust valves side by side. This also turned out to be a very good piston to adapt to a Mini Engine. Racing Speedway, Mini engines do a fair amount of high revs.
"Let us remove your "SHORTS"
PostPosted: Fri Mar 22, 2013 8:23 am
What kinda Mazda? I was told the pistons in my 1380 are from a Mazda 808 but have never bothered to check it out.
PostPosted: Fri Mar 22, 2013 8:28 am
one of the problems with Mazda pistons is they have fairly Thick rings
& another is the material takes a beating on the ring lands when you start running them with hi-comp ratios & hi revs
edit--> i`ve never run them myself , but i know plenty of people who have, hence why i know of some of their problems
PostPosted: Fri Mar 22, 2013 6:40 pm
hi, i would like to also know which type, as i have a set of rods that have bushes fitted to take mazda fully floating pistons
apparently it was also a speedway engine, but i think it may of had piston problems as Matt mentioned hence why these parts were sold
want to use these rods in a street engine so these pistons should be OK
