It is currently Sun Aug 03, 2025 6:58 pm
PostPosted: Tue Apr 09, 2013 10:32 pm
surtees wrote:
Wow they are pretty cheap I was just looking over his site, because I have a 29d fitted to my 1275 but none of there listings are for a 29d can I just interchange it with the 25d spec one like this http://www.simonbbc.com/distributors/4c ... -rotor-arm or wont that work?
It will straight up replace your 29d without a problem.
This might be closer to what you're after. It's a little hard to tell from the text but you simply tell them what curve you are after when you order the dizzy, or simply state your model and the rest is done for you.
http://www.simonbbc.com/distributors/4c ... -red-rotor
 Post subject: Re: Ign Kits
PostPosted: Tue Apr 09, 2013 10:54 pm
Convertible Mini wrote:
The electronic Ignition Kits I sell work fine with Bosch GT40 coils and I have never had a problem with them personally. They can be used with coils having primary resistance above 1.5 ohms. ( Not below) I test each kit before I post it out to make sure they are OK. Suitable for negative systems only and always make sure Coil is connected correctly "Ignition Positive feed to the Plus side of coil". Make sure you measure coil primary resistance before you connect it up. If in doubt, ask questions before you connect it up not after you blow it up because I do not give refunds. That is why I test them before I pack and post. And also .... If you have an ignition problem like burning out points prematurely rectify the problem first before you fit Electronic ignition Kit. These Kits work fine but when there is a problem they blow quicker than a fuse. They do not repair or rectify Ignition faults.
Thanks for the reply. When I brought the car someone had started pulling it apart and I was told the engine was running fine(fingers crossed).
That is why I want to get it started as it sits and check it all out before I start swapping out parts. As you said no point putting a good bit in if there are other faults in the system. Also I don't like wasting my money on parts if I'm only going to blow them up.
Although blowing thing up can be fun but lets not blow up minis!
