It is currently Fri Jul 18, 2025 4:11 pm
PostPosted: Fri May 03, 2013 8:40 pm
No worries, thanks for the possibilities.
Knowing my luck, I'm not expecting a simple fix.
Will let all know when problem is unveiled.
PostPosted: Fri May 03, 2013 9:35 pm
After checking the gear linkages for slop You could also drain the oil and see how many bits drop out
That would at least give you an idea before dropping out the engine for no reason?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri May 03, 2013 9:48 pm
see,,, sensible external work to see internal conditions
just another diagnosis tool
the key is diagnosis
it`s like "measure twice, cut once" , sort of thing
PostPosted: Sat May 04, 2013 7:11 am
The Mini King
Great advice
, Almost any mechanic can fix a problem with a Mini or any other car for that Matter, The real difference between a Mechanic and a Great mechanic is His or her
ability to know what needs Fixing, but as Matt says Very Hard without seeing The Car
