It is currently Wed Jul 30, 2025 7:27 pm
PostPosted: Wed Jun 22, 2005 10:32 pm
Well the head's off now and the gasket is fine......not the same could be said about the valves!!! :shock: :shock: :cry:
Why is the exsaust valves white and the intake valves black? Too lean?
It's a 12g295 head, and now that it's off what should I do to it.....porting perhaps?
foot note: running twin 1 1/4 su's, 1100 crank
PostPosted: Wed Jun 22, 2005 10:46 pm
Get a copy of Vizzard and go for it LOL
PostPosted: Thu Jun 23, 2005 8:44 am
Is there something wrong with No1 piston ? it looks to have a hole in it :shock: :shock:
The exhaust valve gets hotter than the inlet valve, but it may be getting hot I don't know much about these things :oops:
Roads need more corners
PostPosted: Thu Jun 23, 2005 1:44 pm
One thing I'll tell ya -gotta start running coolant instead of water - look at all that corrosion.
PostPosted: Thu Jun 23, 2005 1:52 pm
big = intake (as ive finally learnt!)
piston one looks like its just got a drop of water on it
simple work to head = from $600 from mini places
while the heads off clean the gunk you see in the water channels
replace the head/block adapter tube on the head (far left little tube under thermostat housing
and clean the block surface
isnt it great taking a head off a car!
Inconspicuously Conspicuous
PostPosted: Thu Jun 23, 2005 1:57 pm
Where are you looking?
I can see what looks like a droplet of water sitting as bead on top of the oil on the piston.
PostPosted: Thu Jun 23, 2005 2:10 pm
The second photo seemed to look like a hole but I think it is probably not now it might be the reflection on the droplet that makes it look that way, I was thinking it was a very symetrical hole but I wasn't sure how these things formed :oops: :oops: :oops: Sorry didn't mean to panic anyone
PostPosted: Thu Jun 23, 2005 2:39 pm
I'd be worried about what happened to the rest of that valve (no. 2 exhaust)!! :shock: :shock:
Oh and practise on a junk head (like 12g202's :lol: :lol: ... waits to be flamed....), and after your sure you won't bugger it, go to town.
Better yet, sell off the 12g295 while it's in 'pre-worked' condition and get a 12g202 worked fully. Especially if you're gonna have a go yourself!!
Otherwise just clean it up and have unleaded seats inserted, & have it mildly ported. the '295 chamber design is already pretty good, & the ports are fairly close to right already. Can be improved tho'
Good luck
Matt
