It is currently Thu Aug 07, 2025 8:09 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Radio wiring
PostPosted: Wed Oct 02, 2013 10:13 pm
disconnect the radio earth from the battery, and stick it on the non-battery side of the isolator switch.
although you are using an isolator switch, which effectively disconnects the battery cable (depending on which side it is placed i.e +ve or -ve), you are still creating a circuit through the radio -ve wire which will still allow the unit to work because you are not disconnecting the feed side, just the earth side AFTER radio connection (if that makes sense?)
*edit*
Before you connect the earth to the isolator switch, leave the isolator switched on and disconnect the radio earth from the battery to see if the unit still works. May have another earth from amp/aeriel/speakers mountings.....
PostPosted: Wed Oct 02, 2013 10:51 pm
Ok my thoughts is your chasing an earth. Something in your car is trying to draw a currant when you isolate the battery. Do you have an immobiliser or alarm. Whatever it is will most likely be on the same circuit you connected the red wire from you radio to as the radio turns on.. Its not the radio as it still has its earth when you isolate the battery.
Hope this helps.
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Oct 03, 2013 8:22 am
Hope this helps.
Rodney
Like he said....
some other component in the car is using power and is getting around the isolator by making a circuit to earth through the radio.
PostPosted: Thu Oct 03, 2013 5:02 pm
Thanks for all the help guys
as said it is a earth leakage type problem
and guess what ?
I found IT :D
It is the interior light door switches !
Ignition off, isolator switch off [no power flow through switch ]
open door radio comes on , push door button in radio goes off ,
remove light globe from interior light radio goes off .
with the isolator switched on [power flow ] everythhing is as should be
I can turn the radio off on the front of the unit itself , but once the doors are shut it turns it self off , so now I know it is not going to be going non stop and flatten the battery , :lol:
MARK
PostPosted: Thu Oct 03, 2013 5:14 pm
Well done...
Minis..
1975 van
PostPosted: Thu Oct 03, 2013 5:20 pm
That is so random...
PostPosted: Thu Oct 03, 2013 5:31 pm
I call the little ba$t*rd "PC " [ problem child ]
one of a kind my little PC
OPTIONS would you like curtesy light
or curtesy radio ? :D
Mark
PostPosted: Thu Oct 03, 2013 9:36 pm
nice find weird but nice find
PostPosted: Thu Oct 03, 2013 11:04 pm
Who'da thought eh , that would of tested your patience eh , :P .
PostPosted: Sun Oct 06, 2013 7:17 pm
OK all sorted now
I rerun the earth wire to the body of the car , didn't really want to do this because it by passes the isolator , I have a fuse in this line , from this body earth to the radio harness earth ,to the body of the radio itself and to the aerial earth
every thing is as it should be with the radio now , the interior light works with the isolator isolated ,
it is drawing earth through the body earth .
I will replace the fuse with a reset circuit breaker when I get it :D
Installed an electric brake light switch today as the hydraulic one has failed , AGAIN :evil:
Mark
PostPosted: Sun Oct 06, 2013 7:35 pm
Yeah most of the hydraulic switches are rubbish now. The old original Lockheed ones lasted for a zillion years.
"it doesn't matter how cheap it is if it doesn't work".. :x
