It is currently Wed Jul 30, 2025 7:23 pm
PostPosted: Thu Jun 23, 2005 12:50 pm
bnicho wrote:
If you were doing a dual battery conversion, you could fit the second battery in that dead space behind the existing battery and under the upper floor.
I got tired of not being able to put the seat all the way back. So I made a hatch through the upper floor and fitted a universal battery tray from Bursons to the floor pan. Then I dropped in a Slimline battery DIN-53L, as used in lots of european cars and commonly available at your auto parts store of choice. The negative cable was long enough to reach the new location, but I had to extend the positive lead. The whole exercise took me three hours and cost about $120. Now I can put the seat all the way back. :)
Not a silly idea at all. How abouy putting the batteries on a slide out tray for checking.
Chris
Everything I like is either
PostPosted: Thu Jun 23, 2005 2:33 pm
my input on what i would do to my van if i had the money.
I want to make some sort of seat mechanism that makes the seat
flip up toward the dash, and bring up some sort of flat piece of something to extend the load area, hence having more sleeping room. then turn it into a 70's shagonwagon.
OR
go more ocnservative and put wood all around the inside load and make it more classic load wagon. i dunno yet, it will be spensive i think so will have to wait till after uni
PostPosted: Thu Jun 23, 2005 5:00 pm
So does a normal size battery fit under the rear tray?? I was going to mount the batteries under there somewhere, and maby on a slide tray of a sort as well to make it easier to get in and out, should be easy enough if the batteries fit hieght wise under the tray? And eventually there is going to be an elaborate system in the back of my van so thats why i am going for the dual battery setup straight up
Life's a garden.... Dig It!
PostPosted: Thu Jun 23, 2005 6:19 pm
Fellow Vaners..Are we keeping the Original starter button next to the Hand brake... :?:
I only intent to place a Sub Box's (removeable) at the rear doors and Possible Ally covered on the Sides as Marcia will be used for fun also :wink:
PostPosted: Thu Jun 23, 2005 8:20 pm
Do a SAAB and put the ignition switch and a big red push starter between the seats. Mine is a clubby so I have to have the switch on the column.
Chris
PostPosted: Thu Jun 23, 2005 8:29 pm
Im definately keeping the button. It is very characterful
PostPosted: Thu Jun 23, 2005 8:34 pm
Yep, love the button.
PostPosted: Thu Jun 23, 2005 10:55 pm
A normal size battery just about fits under there, but there is very little clearance for the terminals on top. Certainly there would not be room for a slide out tray under it as well.
With a slimline battery you should have the clearance for the slide-out tray.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Jun 23, 2005 11:08 pm
Can you get a Pick by chance...I'm still thinking of a previose thread :wink: ...yep I still like the idea....who would nomal think of such a big button being a kill switch :lol:
PostPosted: Fri Jun 24, 2005 12:39 am
No I can't find a pic. It also locks the gearlever instead of having a steering lock. I wondeeeer if.... Have a look at the next one you see in a car yard and let me know what you think.
Chris
Users browsing this forum: No registered users and 36 guests
