It is currently Thu Jul 31, 2025 6:09 am
 Post subject: Re: Gear Stick Rattle
PostPosted: Tue Jan 28, 2014 10:36 pm
My remote linkage has a bolt in the side fitted with a bronze bush (assuming its bronze) with a spring behind it. Is this the bottom nylon bush referred to previously? It puts compression on the rod holding it firmly against the remote tube.
If so it's a mean little spring, hopefully the new springs are as stiff as the old ones :)
PostPosted: Wed Jan 29, 2014 8:21 am
The Mini King
No The bottom Nylon bush referred to is the nylon bush at the bottom of the gear lever
and there is a spring that is fitted underneath that nylon bush
