It is currently Tue Jul 22, 2025 5:13 am
PostPosted: Wed Feb 12, 2014 7:44 pm
1071 S wrote:
Maths are your friend....
I=P/V.... Add up your power requirements Headlights (200W) Spots (200W) ignition (5W - previous post) stereo ??? wipers???
Say.. 600 divide by 12 (V) = 50 (Amps)
So your alternator needs an output north of 50 A to charge the battery on a dark and rainy night.. If your close the envelope add a bit for losses (heat)....
Good luck, Ian
Ignition is about 5 Amps
PostPosted: Wed Feb 12, 2014 7:51 pm
Good luck, Ian
Cheers, I don't need an alternator! My headlights are powered by candles, I don't drive the Mini in the rain and I don't have a stereo! Ha ha.....
I've gone with the 70 Amp just because! But having a wiring issue! See my new thread 'Alternator Wiring Issue'
Thank you for everybody's input :D
PostPosted: Wed Feb 12, 2014 9:15 pm
Ignition is about 5 Amps[/quote]
60 watts ??? seems a lot - am i missing something??
Cheers, Ian
PostPosted: Wed Feb 12, 2014 9:37 pm
Cheers, Ian
Its not too hard to figure out if the coil Ohms (Rcoil) on the primary winding is anywhere from 0.7 to 3.2 Ohms. Higher ohms for points ignition, and lower for transistorized ignitions.
After that, Icoil=Vdc/Rcoil which will be between 17.4 and 3.5 Amperes because of the differing coil resistances. Most Minis will be at the 3 to 5 amp end as they use a higher Ohm coil because of their points ignitions limitations (points melt with lower ohm coils, like the Bosch GT40R coils for example).
There's a little more to it. The current through the coil pulses with the duty cycle. The coil is charging for around 60 percent of the ignition cycle per plug. So the current will be 60 % of what we have calculated here. However, countering this is Vdc which is actually around 13.7 volts, which increases the actual coil consumptions.
But for all intents and purposes, you can see how we arrive at a rough calculation at 5 Amps(ish).
