It is currently Wed Jul 23, 2025 8:13 am
 Post subject: Re: Damaged Gears!
PostPosted: Thu Apr 10, 2014 9:13 pm
If I get an 18 tooth pinion with the 64 tooth crown wheel I'd get 3.55, or should I just bite the bullet and get the correct combination for 3.44?
PostPosted: Thu Apr 10, 2014 9:43 pm
No can do.
You can't mix and match pinions and gears. The tooth profiles are not machined to match each other and they will fail.
PostPosted: Thu Apr 10, 2014 9:49 pm
18T pinion won't go with your 64T crownwheel.
18T is only used with a 62T crownwheel, and be careful, because there are 3 of these.
The one you need is marked 22A411
@Mick, you can use the other pinions with various crownwheels, but NOT the 18T one.
eg the same 17T, 22A399 pinion is used with a 64T crownwheel (3.765) and a 62T (3.647).
PostPosted: Thu Apr 10, 2014 9:52 pm
Cheers Doc.
PostPosted: Fri Apr 11, 2014 10:10 am
The Mini King
A good second hand 18/62 crown wheel and pinion should not cost you to Much
I like the 3.1:1 Myself but they are around $300 for a new set, Others may disagree
PostPosted: Fri Apr 11, 2014 10:53 am
$300 isn't too bad. So John sell me the 3.1:1, what's the good, bad and ugly of this set up? :D
PostPosted: Fri Apr 11, 2014 11:17 am
3.1 is a good ratio in a 1275, particularly if you do much highway work.
Me? I run a 3.647, bwahahaha.... 8)
PostPosted: Fri Apr 11, 2014 12:00 pm
The Mini King
I Like them because they are good for cruising, I find I am not thinking I need to change
gears but find I am already in top gear, and the motor is not revving itself to death @ higher speeds
the down side is You lose a little of the mark.
others May have a different opinion.
