Kennomini wrote:
(1) If it's a bare shell start with the brake, fuel, battery, hydro lines that run under the floor. Then fit the assembled subframes (steering rack first for the front and don't forget the hand brake lines with the rear frame).
(2) Then once it's a rolling frame make it steer and stop. Pedal box, brake and clutch MC's, hand brake, steering column.
(3) Then your wiring loom, dash, lights, wiper motor, fuel tank, pump & filter. If you want you can finish the boot off now, mount the boot lid fit the battery (don't hook it up yet) and you have one section finished.
(4) Fit the interior, hood lining first, carpet, door cards, seatbelts & seats. Mount the doors and fit all the glass. Now the second section is finished.
(5) lastly is the engine, drop it in, install engine accessories, connect exhaust, carby and hook up fuel lines, radiator and hoses, connect battery cable and all engine wiring. Get it running before you fit the bonnet and grill. Be careful when first starting the engine, this is when you can have fuel, oil & coolant leaks, also keep an eye on electrics you don't want it to short out or catch fire, keep a fire extinguisher handy (or two, one big and one small) and have the battery easy to disconnect (no spark=no fire).
Easy peasy.
awesome thanks,
ive pretty well followed this, as the bare shell has the brake and hydro lines still attached. i did however forget the hand brake step, and am not sure how to mount the steering rack, maybe ill go jack up my other mini and take a look at it, though its a bit hard to get to right now 0_0
Thanks
Leroy.
1967 Mini Deluxe bucket of rust and mismatched parts powered by a 1360cc and a destroyed gearbox missing second gear
