It is currently Fri Jul 18, 2025 10:41 pm
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: SU Needle suggestion
PostPosted: Thu Dec 25, 2014 7:59 am
Thankd doc. I'll stick with the red springs. Is it ok to use needles that are a few stations longer??
PostPosted: Thu Dec 25, 2014 10:05 am
yes, no problem there.
PostPosted: Sat Dec 27, 2014 2:44 pm
Forget yellow springs, they are too heavy for HS2 or HS4. Only any good in HS6.... maybe.
Blues are lighter than reds. Too light for a 1330 with HS2s.
I don't often disagree with the Doc, but... :shock: :?
Yellows are NOT too heavy for an HS2. :shock: This goes against all conventional modern thinking, but is wholly in tune with old thinking. The determining factor for springs isn't the size of the carburettor, it's the size differential between the carb and engine. Vizard's suggestion was to use light springs with big carbs on small engines, and heavier springs on small carbs on big breathing engines. So, for a stock 850 running an HS4, he definitely wanted a blue needle. For a 998 with a flowed head, he wanted red.
I'll quote from page 8 of 'Tuning SU Carburetters':
It is best to use the Red spring but if the carburetters are suspected of being on the large size for an engine then the blue should be tried. Conversely if the instrument is only just large enough, a stronger yellow spring might be required.
Italics are for emphasis.
I have a 1301 with a VERY flowed head, a warm road cam, oversized full race 3 into 1 headers (the join in the pipes is under the body), and twin HS2's. I'm running yellow springs. They work better than the Reds did. And it's most noticeable at part throttle, where I have more fine control than previously. The throttle is less of a switch between nothing and everything. :)
Everything I've read says you want the dashpots to be fully open 500rpm before peak torque. A weak spring - a blue spring - will allow the dashpots to rise faster than regular springs (red), and faster again than strong springs (yellow). If you have a shallow breathing engine - say, a stock 850 with a HS4 on it (yes, I know, a very unlikely combination), you just won't develop enough vacuum to fully compress the spring if you've got a yellow or even a red spring. You need the blue spring. That allows you to use the full depth of the needle. If, however, you have a deeply breathing engine with smaller carbs - say, a 1330 with a GR head and 'only' twin HS2's - then blue springs will provide far to little resistance. And red springs MAY also provide too little resistance - allowing the dashpots to be fully raised more than 500rpm before peak torque.
Your spring sets two things - one is the airspeed, the other is the timing of your fuel curve. Your fuel curve is set by the needle. If you have a heavier spring, then the dashpots will be lower - relative to weaker springs - which means you have a smaller aperture through which the engine can breathe. Which will therefore see an increase in airspeed to fill the engine. That increase in airspeed will also see an increase in the quantity of fuel dragged through the needle at a given station (higher airspeed = higher vacuum). It effectively richens the whole fueling curve. But the relative fuel curve of the needle remains the same, compared against itself. As in, the idle-end stations will still deliver proportionally less fuel than the wide open throttle stations, just the whole curve moves up the scale.
When I say the spring sets the timing of your fuel curve, I mean that it determines how much load it takes to get to full fueling. If you've got blue springs in with your engine, you'll have full fueling earlier than the engine wants it. Which means that you'll either run rich, or, more likely, you'll end up running lean at the top end, and fail to get the full potential of your engine. So, you could also describe the spring as setting the length of your fueling curve across your rev/load range - with a weak spring, all the fueling changes are in the first part of the rev/load chart, with too large a section left at max fuel. Too heavy a spring, the fuel curve extends beyond your engine's revs/load capacity (i.e. you might need to rev it to 9,000rpm at full load in order to drag max fueling - which is useless). So, having the right spring is pretty important! :lol:
Bear in mind, also, that ANY SU needle can be tuned at idle. And the standard carb tuning procedure for SU's doesn't determine correct needle selection, it only tunes the idle. It relies on you already having the correct needle selection. The same is true for a Colortune. Pretty well every SU needle for a given size carb is identical in station 1. I've only really looked in depth at 0.090" needles, but I've hardly seen something that doesn't have a first station size of anything other than 890 (looking at the best Needle comparison site, Mr Kerr's SU thingy). So, that means pretty well any needle - right or wrong at the top end, it's irrelevant - can be tuned at idle. :roll: That tune doesn't indicate anything, you're better off reading the plugs (something I've had success doing - in spite of unleaded fuel).
The correct solution, with your engine and I believe also mine, would be not to find another spring, but to increase the carb size. :o That's what WinSU recommends for me - twin HS4's, or a HS8. Can't imagine yours is any less - especially given it recommends the same needles for me! HS2's were correct for stock S's, but Police cars (which, from what I understand, didn't have worked heads) had HS4's. There are Minis on here running twin HS6's. With the quality of your engine, everything I see in it says the choke point in the engine is the carburetion. HS2's are on the small side for it, and a set of bigger carbs would certainly work. Definitely HS4's, maybe even HS6's (though they may then require blue springs!). Though I'm not in any hurry to spend the coin to swap up in carb size, and don't blame anyone else who feels the same way.
I wouldn't be afraid of trying the yellow springs WinSU suggests. That's why I went that way, and I've not regretted it. In fact, I'd go to the Yellow spring before I changed the needles... AC Dodd recommends the order to set up is Damper, Spring, Needle, and Oil (last!). Most say twin HS2's are only good up to 75bhp, WinSU's estimates for power from our engines is over 80bhp. Whether that's right or not, it certainly shows that we're at the very top end - if not above the top end - of standard use for twin HS2's, which means we can use Yellow springs (going back to the comments from the SU Tuning guide above). My current needles - M's - are too rich according to WinSU, but with some tuning and the correct springs (because I used these M's with Red springs previously), I have no issues with fouling (which I had with the Red springs). It runs very nicely. :D
PostPosted: Sat Dec 27, 2014 3:03 pm
Surprisingly, I agree with you, in your case.
Sounds like you need bigger jugs on your big motor then. :)
Only motor I came across with yellow springs went harder when I put red ones in it. It obviously struggled to lift the pistons against the ^%#*! load of the yellow springs!
PostPosted: Sat Dec 27, 2014 4:01 pm
My thing used to have a Weber DCOE45 on it, I didn't realize I was making a mistake not paying the extra $500 for it when I bought the car. :shock: The former owner had pulled it off and reinstalled the HS2's when he went to sell. :? Guess he wanted the extra cash, though it did make the car a bit of a dog to test drive (given the HS2's weren't tuned). :roll: It's ok, I like my little HS2's, and I'm sure they're part of the reason why I'm getting 6.7L/100km (no slow driving, mixed town/highway, with a 3.1 diff). And I got to learn a good amount about tuning HS2's (I'm guessing the Weber was better tuned for the engine). :)
I don't think my engine's that big, but it definitely can suck. :D I'd have expected Hanra's GR-headed beast would be similar, too. I think we, as in, myself and Brad, are just the odd remaining few who are living in the dark ages, sticking with stock carbies, when everyone else has gone big Webers (or Dellortos! Thinking about it, as Mr M. Read pointed out to me, the choke size in a DCOE is the true throat size, so a 36-38mm throat (not uncommon) makes them effectively equivalent to twin HS4's for throat diameter) or bigger SU's (bigger than standard - i.e. twin HS4's, twin HS6's). :P So we've got to stick with dark ages logic, rather than just getting the right carb size to run in the carb's sweet spot (with Red springs). :)
I'm very confident your 1360 (or Gafmo's 1412) would need yellow springs with HS2's - if anyone were silly enough to try those engines with HS2's! If my little 1301 needs yellows... 86.6bhp fwhp is certainly too much to pump through HS2's, the only hope of getting a progressive throttle with twin HS2's and that engine would be yellow springs. Though I can't imagine it'd still hit the full 86 fwhp.
PostPosted: Sat Dec 27, 2014 6:20 pm
I agree twin HS2s are too small for a 1275 if chasing HP.
I had twin HS4s on Barney (1293) with a Wade 104 cam and Corolla 1.46:1 rockers.
On the same dyno at MRC that we put mine on, it made 59.4HP ATW. That was with 1100S inlet valves, minor porting work, and a Perry 3-1 freeflow exhaust. I'm sure it would have been less with twin HS2s.
My 1310 motor (pre the 1360 build ) made 75.4 on the same dyno with an RE13 cam, same head, carby, 1.5 rockers etc I'm running now.
PostPosted: Sun Dec 28, 2014 10:51 am
That's great info their mate. Thank you very much. Yep I agree the HS2s are on the small side, my 1330 is still running standard 1275 valves, not Cooper S sizes. The rocker gear is standard. I just can't justify spending the money to upgrade to twin HS4s.
I never got any details of the work done on my cyl head and cam grind from GR when he did the work on it in 2000. Was $1100 for hardened valve seats, head porting and cam grind. All I ever got was a receipt.
My LCBs, the Y piece joins midway down the motor, then the two pipes come together at the base of the motor. No idea on dimension of the pipe. The rest of he exhaust is a straight piece of 2in pipe. I think I bought the extractors from Readspeed when they were in Morningside around 2002.
Tadhg, do you think I should give my M needles another chance with yellow springs? What oil are you using in your dahspots? Did you try any of the needles suggested by WINSU?
PostPosted: Sun Dec 28, 2014 5:42 pm
What is also a suggested spark plug gap for my set up which consists of a Pertronix Ignitor electronic ignition and Pertronix Flamethrower coil? I've got NGK BP5ES plugs.
PostPosted: Sun Dec 28, 2014 5:44 pm
I had a Pertronix Ignitor in my 1310S motor, and used to run .035" plug gap.
PostPosted: Sun Dec 28, 2014 11:11 pm
So, you've got 30cc more than me, but I've got bigger valves (35.6 inlet, 29.25 exhaust - it's an AEG163 head (Mk 1 S) with hardened inserts, 23.8cc chambers, it rocks!), although driven by Rover rockers (i.e. the sintered things, not true 1.3's, corolla or 1.5's). Hence why I'm also not in a hurry to spend on HS4's. I'm confident the HS2's are currently the choke point, but going to HS4's will just mean the valve lift is the choke point. :roll: :lol:
I must admit, I didn't actually try the needles specified by WinSU. :oops: Primarily because needles are generally $30/pair plus postage from most shops, and, without other options (other than M's) on hand myself, it was too much expense and effort at the time. :| Especially when my first move was to try the yellow springs, which did give a good result. 8) My primary issue before going to Yellow springs was that I had fouling at part throttle. Before that, I was looking at needles. That said, if anyone has a set of ADN's they'd like to donate to a good cause... :lol:
On the other points, I'm running air tool oil in the dashpots, and, as I'm running a MegaJolt, I've got 0.040" gaps. Previously, with a SimonBBC Red module, I was running only 0.025" on the plugs. But that was with Red springs, and the plugs fouled a bit. With a good tune, the bigger the gap, and clearly the Doc was able to get more out of a Pertronix than I got out of my imperfectly tuned Red module, GT40 and 5's. What gap are you currently running?
In terms of what to do... Whatever's at hand is the first thing to try! :lol: You've tried the three needle setups you've mentioned you have. You also mentioned H6's, which are again similar to the AH2's and 3's, but a little leaner everywhere, particularly at the top end. If you don't have anything more than the Blues, Reds and three/four sets of needles, I'd then buy the Yellows first. Before any other needles.
Springs are the same price as a set of needles, but changing the springs means that your existing 3-4 sets of needles are unknowns again, so they're certainly worth trying again. And then I'd start with the M's. M's are leaner than both the AH2's and 3's you have, and the needles suggested by WinSU are leaner again. Even at their richest, which is several stations longer! So it makes sense to start with the leaner needles. And of course, each time you tune, the better you get. Especially since you have the benefit of the LM-2. :)
PostPosted: Mon Dec 29, 2014 7:51 am
Cool, yeah Ive got a few needle selections. M, AH2, H6, 3, EB and a few others. I will try the yellow spring with the needles that I have. Only issue is... where to buy a yellow spring from... Cant see any listed for sale in Australia? On the UK mini sites they are listed.
PostPosted: Mon Dec 29, 2014 7:59 am
Don't buy a yellow from a mini shop then! MG shops should have them :wink:
http://www.mgspareparts.com.au/index.ph ... -su-detail
PostPosted: Mon Dec 29, 2014 9:00 am
Thanks mate, Ill shoot them an email to see if they have stock of springs to suit HS2s. That spring linked appears to be for HS6. I would imagine there would be a difference?
PostPosted: Mon Dec 29, 2014 10:05 am
Yeah a yellow was common in HS6, will fit an HS2 though. Same diameter... a bit shorter, thicker wire.
PostPosted: Mon Dec 29, 2014 10:26 am
Ok cool!!! Thanks Doc. Wasnt sure if HS2/HS4/HS6 springs were all the same size diameter wise...
Cheers.
