It is currently Fri Jul 18, 2025 1:39 am
 Post subject: Re: Coilovers
PostPosted: Wed Feb 11, 2015 9:35 pm
Harley wrote:
You're right Simon - In my case I have 13x7 -7s, and 13x6 +15 wheels as a backup - a difference of 34mm where the shock absorber is!
Doesn't look like there's that much space in the pics above - and he has metro brakes!
the bottom brackets you can see there have the damper waaay out over the balljoint. No doubt that's to give the spring clearance away from the crossmember, but there must be some extra clearance in it somewhere
PostPosted: Wed Feb 11, 2015 9:44 pm
I've worked on a mini which has coilovers, not sure of brand though, probably an older setup. Runs on standard 10" steel rims with drum brakes with the built in spacer.
So probably depends all on the design of the shock etc.
 Post subject: Coilovers
PostPosted: Thu Feb 12, 2015 5:00 am
Also the top arm has been moved up in the subframe to give better geometry. Nothing what so ever touches under any side loading at this height. Even when the car is lower the only thing that touches is the tire to front arch which I can trim anyway. I also have had no issues with ball joints what so ever and the car is constantly checked. So I'm completely confident in the handling, stopping and clearances of my car.
I dont like oil leaks
