It is currently Sat Jul 19, 2025 9:32 pm
PostPosted: Mon Mar 09, 2015 12:46 pm
Irish Yobbo wrote:
jprior2912 wrote:
Thanks everyone. It doesn't seem too bad to do then. Does anyone know the inlet/ exhaust clearance for a GR Re83 cam? It aas mentioned a stock cam is 12 thou
James
According to the good doc here, the clearance for the RE83 cams is 0.016" for 1.3 rockers.
Awesome, thanks - This may seem like a really rookie question.. But how do you know what type of rockers you actually have?
PostPosted: Mon Mar 09, 2015 1:05 pm
Are they standard type or roller?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon Mar 09, 2015 1:12 pm
Pressed steel look like 2 pieces of sheet steel stuck together. Sintered are very wide and smooth. Forged are thin and solid. I am sure that there are heaps of photos posted somewhere on here.
PostPosted: Mon Mar 09, 2015 1:42 pm
They are std not roller and appear to be the sintered type
PostPosted: Mon Mar 09, 2015 1:58 pm
Set all stock rockers to .016".
1.3 rollers set to .016-.017".
Should really not use 1.5s on an RE83...
PostPosted: Mon Mar 09, 2015 1:59 pm
Here are some ratios that Doc has provided us in the past. viewtopic.php?t=79040
PostPosted: Mon Mar 09, 2015 2:14 pm
Cool thanks!
I have got A+ Sintered 1.18:1 std rockers then.
So .016 it is, same for both inlet and exhaust?
Cheers :)
PostPosted: Mon Mar 09, 2015 2:16 pm
yes.
PostPosted: Tue Mar 10, 2015 1:45 pm
Thank you everyone for your help - She's running beautifully now. Such a relief!
PostPosted: Tue Mar 10, 2015 1:50 pm
Well done mate
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Tue Mar 10, 2015 3:52 pm
some time in the future you will be able to call yourself a mini mechanic
like the rest of us :) :)
65 panel van Sprog
73 panel van Iggy
PostPosted: Tue Mar 10, 2015 4:06 pm
Good work James!
PostPosted: Tue Mar 10, 2015 4:22 pm
Nice to see Ausmini in action. Great result!!
PostPosted: Tue Mar 10, 2015 7:26 pm
ohh yeah, I called it 8)
PostPosted: Tue Mar 10, 2015 7:37 pm
