Everything went well today and I've pulled the rack apart to inspect what actually needed replacing.
Ended up needing:
Nolathane bush
rack boot kit
proper small hose clamps for the rack boot small end
lock nuts (pulled both apart to inspect & clean - going this far why skimp and only do one)
2 tapered washers
pinion seal
2 x anti rattle strips for against the rack/u bolts
pinion to body seal thingy
I found that the bearings were in good nick and I just plan on cleaning them and regreasing and they should be good as new. The pinion and rack look in awesome condition which is a testament to keeping the rack filled with oil (with good boots). I'm taking a bit of a gamble on not needing any new shims upon reassembly. Ending up spreading my money around between Karcraft and John at Mini Kingdom.
I still need to get some locktite 515 and some EP140 gear oil (hoping to find some monograde stuff otherwise will go 85-140 gear oil).
I noticed when pulling everything apart it looks as though there was some grease mixed in with the oil in the rack. Should I consider doing the same thing again or just leave it at oil only?
<edit> with this hex bore in the bush that replaces the felt, does it slide on as is or should I mount it up in the lathe somehow and bore it out? Obviously the original felt was round
