It is currently Mon Aug 18, 2025 11:15 am
PostPosted: Thu Aug 27, 2015 7:42 am
peterb wrote:
I use a floor jack at home with modified pad. Got the original one in boot, looking at it I don't think its ever been used. :-)
I modified the wheel brace though, to suit the Mamba wheel nuts. Sometime people should check if they have mags, sometimes the nuts are not the same as original.
$20 aldi torque wrench with 11/16 socket on it does me as a wheel brace a lot longer handle than a usual 4 sided brace and the nuts get put back on at what I think is the right torque setting from the workshop manual
PostPosted: Thu Aug 27, 2015 8:33 am
I scored a scissor jack out of an EL Falcon for my daughters 04 Bini , they are shorter than the old style scissor jacks and work a treat .
PostPosted: Thu Aug 27, 2015 9:48 am
Phil 850 wrote:
It's also surprising the number of people that don't realise you are meant to have the door open when you use the original jack.
Is this so that you can wind the handle round & round a lot faster than doing half a turn at a time.
I never thought of that :idea:
Yes.
People either have no handbook or have never read it.
I can't imagine how long it would take if you had to do half a turn at a time, let alone the risk of damaging the outside of the door.
You do need to be careful when finished jacking up not to let the door slam onto the top of the jack or you end up with a nasty ding in the door pocket!
PostPosted: Thu Aug 27, 2015 1:52 pm
Which is still better than the nasty dent you get when it comes off the jack and you didn't open the door first!
I gave up on genuine jacks many years ago. A scissor jack from supercheap is far more convenient and effective. Especially if you have to jack up the passenger side on uneven or soft ground on the side of the road.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Aug 27, 2015 6:36 pm
What jack did mokes have, same as vans?
PostPosted: Fri Aug 28, 2015 12:57 pm
Yes.
You can still get nos Leyland handbooks from mg spares Smithfield for 71 to 74-75 models the 75-78 models ones have different pages for the pollution stuff
I got one from there warehouse http://www.mgspareparts.com.au/index.ph ... ini-detail
And keep the jack thread well greased my first one that came with the car the theads were striped
Users browsing this forum: No registered users and 136 guests
