Icarus wrote:
The RACQ just left the mini, more puzzled than ever! There is healthy spark at the plugs and petrol is getting through to the carby (via fuel filter and petrol converter thing), it just appears that no fuel in in the bowl? (That's what the RACQ guy said).
I would use flashlube rather than one of those petrol coverty things (although I think you can get an incar flashlude system but I just add some each time I fill up)
Fuel not getting into the carbie (ie no fuel in in the bowl) is generally as I understand it caused by incorrect float settings or stuffed vale and seat. The float trys to maintain a level of fuel in the carby which is then used from there... The valve is worked by the float if it stuck closed not fuel will be let in, no go....
Icarus wrote:
He sprayed the carby with "Sure Start" which he thought would work a trick, but still didn't fire.
What's Sure Start? If the problem is that there is no fuel getting into the bowl then I don't see how this will help.
To see if that is your only problem you can get a spray bottle with petrol in it and as a friend tries to start the car spray petrol down the throat of the carby (with the air cleaner off) this sort of does the job of the carburettor so you can get it started... if it does start then that's good but you will have to work out why the fuel is not getting into the bowl
Icarus wrote:
Doesn anyone have any more advice about the dashpot in the carby? It looks like it has a mixture of oil in it? What sort of consistancy should it look like? Would spraying the carby cleaner stuff have done more harm than good?
Here is a link explaining more about SU carburettors hope it helps
http://www.zparts.com/zptech/articles/mal_land/ml_sucarb2/images4/SUcarb_111601b.htm
To tell the truth I can't remeber how much oil should be in there, I should know but can't remember. As the link says it is to stop the piston inside rising too quickly when you open the throttle. I don't think this is your problem and it probably doesn't matter so much until you get the car going properly. As far as what oil to use there was a fair amount of debate on this but I think ordinary engine oil is OK but may not be the best.
Hope this helps
