It is currently Wed Aug 06, 2025 2:46 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Aug 02, 2005 9:56 pm
I dont actually own one...pulled that piccy off google.
I borrowed Kazjim's one, its exactly the same...but not shiny.
cant imagine they would b too expensive though ?
No more Minis!......For now.
PostPosted: Tue Aug 02, 2005 10:42 pm
Hitting one hammer with another is not a clever thing to do. :( I had a a chip fly off one ball-peen hammer and slice into my hand after trying that trick. The Doc removed most of it but there's still a bit of shrapnel floating around in my palm which comes to the surface occasionally :shock: . I''ve used a scissor type splitter ever since and used it on everything from Range Rovers to Minis, they work well and are much safer!
Curly
PostPosted: Tue Aug 02, 2005 10:56 pm
i've done this, just smashed away merrily with a bfh till something happened
PostPosted: Tue Aug 02, 2005 10:59 pm
willy...I think you need to swing Bigger
Get a propper ball Joint spliter and you will never have a trouble again :wink:
PostPosted: Tue Aug 02, 2005 11:00 pm
Haha really.
I was hitting it fairly hard, and lots of times.
Nothing was happening.
Tomorow i'll hit FARKEN hard. 8)
PostPosted: Tue Aug 02, 2005 11:14 pm
not just the wrist....full shoulder swing mate :wink:
PostPosted: Wed Aug 03, 2005 12:33 am
yeah put your back into it..
maybe get a run up.
PostPosted: Wed Aug 03, 2005 12:34 am
Should i take the gaurds off so i've got a bit more swinging space?
PostPosted: Wed Aug 03, 2005 12:39 am
so what are you trying to do exactly, are you installing front hi-lo's?
PostPosted: Wed Aug 03, 2005 12:42 am
Yep and while im there, i'll be putting in a new RH CV boot as the one in there is split.
PostPosted: Wed Aug 03, 2005 5:40 am
"And here come the safety marshalls"
My brother is an eye surgeon. He wants to buy a Ricer 350Z but that's another story. He sees a lot of people with shards of metal in their eye, which is worse than a couple of sparks from a grinder. Almost always it is from hitting metal on metal (as described in this thread). The bigger mass of a shard of metal (I think) means it goes deeper into the eye, and he has to use a needle to coax it out - obviously with no anaesthetic. Gives me the screamin' hab-dabs thinking about it, so I always grab some safety glasses or goggles. And so should you.
PS. I bought a scissor-type ball joint seperator as mentioned from SuperCheap - no bolt. Not much use.
PostPosted: Wed Aug 03, 2005 8:44 am
If big willy is that bad a shot that he can hit both hammers instead of the balljoint in that small space then he better go buy that splitter. As for me, as an old blacksmith/boilermaker/welder give me a couple of good hammers anyday.
When a Doctor checks my eyes he can nearly always tell I was a welder by all the burn marks in my eyes. I did my trade before safety was a real issue and coped a few hot bits in both eyes over the years from grinders.
PostPosted: Wed Aug 03, 2005 9:40 am
Err, correct me if I'm wrong but should you not take the nut off the ball joint first? :lol:
Well here's a story: I broke 2 of those ball joint separator thingies to get mine apart... although mine were made in china crap. I eventually used a fork splitter and it did the job. After I split it once, the come off really easy every time after that. It's just that it probably hasn't come off in years and was tight as a Chinese Mother-in-law :wink:
PostPosted: Wed Aug 03, 2005 1:23 pm
I used a different method and didnt involve much strength cos im weak :D what you do it jack the car up, then put a peice of hardwood or something unter the top arm thing then lower it a bit leaving the nut just above the thread, then you can beat the top of the nut and it should pop off pretty easy, i think J_A_M told me this, i think i have some pics if you want em, and for the bottom jack up from the nut and hit the arm ;) ;) easy peasy, left drum removal time, 4 hours, right drum removal time 10 minutes...or so :lol:
I have a problem.. apparently
PostPosted: Wed Aug 03, 2005 3:43 pm
Woop woop!!!
Got the right top one split, haven't attempted the left side.
I was in so much of an excited mood that i JUST had to tell you :D
Users browsing this forum: Bing [Bot] and 76 guests
