It is currently Sun Aug 03, 2025 6:32 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 169, 170, 171, 172, 173, 174, 175 ... 568  Next
PostPosted: Sat Jul 24, 2010 1:55 pm
After yesterday's run down the M4 I thought the 1412 was running a little rich, so today I pulled the 170 main jets and fitted 165s, then 160s. Holy shizen Batman, it don't half go now! :P
Now, where did I put my 155s....
Gotta love a Dellorto, no ****** SU needles to buy and try.
PostPosted: Sat Jul 24, 2010 2:59 pm
Put on a new R/H tail light assembly.
Took my son for a drive to South Werribee, then took another turn and drove through Little River then into the You Yangs National Park. Had great fun on 'the big loop' 12KM gravel road. Hamish asked if it was OK to take Mini's "off road"; guess I had to show him! 8)
PostPosted: Sat Jul 24, 2010 3:39 pm
Cleaned the inside. Couldnt be bothered doing the outide... :oops:
Cheers, Ben
- 1974 Leyland Mini S
PostPosted: Sat Jul 24, 2010 4:44 pm
Walked into garage looked at wiring harness which is out of the car scatched my head turned around walked out and closed the garage door.
PostPosted: Sat Jul 24, 2010 5:36 pm
Stripped apart gearbox then cleaned, for about 3 hours then inspected everything. This gearbox has been recently reconditioned me thinks..... Everything is spot on!
Scrubbed and cleaned freshly bored block and re-ground crank. Cleaned new GR 100thou pistons and all the bearings, gapped rings, assembled rods and pistons a little more cleaning then assembled crank in block, checked crank end float, installed pistons and rods.
Now waiting for cam and head.........
Mini, its in my blood........
PostPosted: Sun Jul 25, 2010 7:23 pm
Whizzed around Old Norton Summit and Adelaide to Lobethal roads. 8) Great day for a cruize.
Cheers, Ben
PostPosted: Sun Jul 25, 2010 7:58 pm
Pulled an old steering rack apart to do up, but found it was knackered. The old thick grease was hard and rusty, rack tube bent, rack scored and corroded.
I saved the pinion and bearings... tossed the rest then stripped another. Full of thick gear oil, MMMMMMMMMMMM. Noice one.:D
Oilz is oilz, but grease is crap when old.
PostPosted: Sun Jul 25, 2010 9:33 pm
Drove the Cooper S to Moss Vale and back for MCC Christmas in July.
No snow just lots of rain.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jul 25, 2010 9:38 pm
Went to take the kid back to his Mum's. Got 1/4 the way there when noticed screen needed demisting. What that's not right! Looked at the floor and a stream of green fluid was slowly puddling at son's feet. Turned the heater off, and returned the car back to the garage, naughty car. :oops:
Looks like the heater matrix is leaking, as it didn't seem to be wet at either of the hose connections. My heater is some after market one, not the normal MK I or Cooper 'S' one, so not sure what I should do at this stage if the core is to far gone. Any suggestions? :?
PostPosted: Sun Jul 25, 2010 9:49 pm
gorgeous sunny day here, and I won my local motorkhana 8)
jb007 wrote:
Any suggestions? :?
bung in a clubman heater.....
PostPosted: Mon Jul 26, 2010 6:49 pm
Moved it from one side of the garage to the other to satisfy SWMBO
(and she was right it is much better)
PostPosted: Mon Jul 26, 2010 8:11 pm
Collected my Clutch hose so I can get a Nut for it & took 1 of the wifes coat hangers straighted it and then bent it to the shape I want for the Master Cylinders Pipers. Thats how Long I was at home and was more proactive than on the weekend for the Mini's
PostPosted: Wed Jul 28, 2010 2:35 pm
wow - 2 days of no-one doing anything :shock:
yesterday I drove my cooper to Ballarat and back (400k's each way) to attend a funeral...
PostPosted: Wed Jul 28, 2010 2:58 pm
Ordered a set of Hi-Lo's
PostPosted: Wed Jul 28, 2010 3:45 pm
I'm storing up my limited energy reserves for pulling out my heater and fixing it. 8)
Users browsing this forum: timmy201 and 74 guests
