smac wrote:
Holy crap you don't do things by halves! Never had a wheel let go on me....but then again I do the nuts up
*grin* me neither.. was sitting on the passenger side, and the nut-dooer-upperer was on the other side of the car so I thought, I'll do it next time I walk around the other site.. Course, once the wheels were back on, i dropped it off the stands, messed with the timing (turns out it was 180 degrees out like my housemates car), fired her up. emptied about 2l of oil out onto the ground before I twigged that someone had pulled the oil pressure sensor out of the engine without telling me..
So I cleaned that mess up, removed the oil pressure sensor from the old engine, topped the oil back up, started her up again, and then proceeded to do a rough (i.e. find highest revs) tune/adjustment on the distributor) - doing a proper tune is a three handed job (one to hold the mirror, one to hold the timing light, one to turn the distributor..) , and at that stage none of my housemates were home..
Then jumped in it to take it for a test-drive.. completely forgetting about the wheel nuts
smac wrote:
Still not 100% sure about what you're saying about the idler - did some work on it?? I don't get whether the idler in your gear box was large, or the one in your cover? Either way, you can't just mix and match. It might work to start with, but not for long.
Sorry, I think a previous poster confused things - nothing to do with the idler gear in the gearbox, it's the little bearing that presses over the end of the input drive shaft. The one on the new gearbox was too large to fit my cover.. So I went and bought a gear puller, did a lot of cutting and grinding, and ended up with something that worked to 'safely and cleanly' pull the two bearings off.. then put the bearing off mine that matched the housing onto the new gearbox, and it all bolted up nicely..
smac wrote:
Shouldn't take long to figure out where the lean is coming from, just keep measuring/comparing side to side until you find what's different.
Everything looks the same,lengths, etc, with the wheel off, it seems to be that yoiu can jack the suspension up a lot higher than you could before I lost the wheel.. So my (relatively uninformed on hydro) bet is that something let some fluid out when I went for the dive and it needs pumping up again.. Guess I'll find out if I ever get the damned thing running again and go get the hydro looked at..
smac wrote:
Pick-up problem sounds like carb and/or timing, not head.
Carb, I doubt it, as I just dropped the carbs straight off the old engine on, so it *should* just work? Timing, could be, since I just hand timed it.. but would either of those cause huge clouds of blue smoke? I thought blue smoke was in the oil domain, which would mean the new head is doing exactly what my old head was doing.. - back off at high revs, then apply throttle again, and you'd get big lots of blue smoke..
That's the weird thing - because I wanted the gearbox out of the car that the engine/clutch came out of, we *tried* to give it a pretty good hard drive.. Then discovered 2nd was completely missing.. So we then proceeded to give it an even harder drive in 3rd/4th, and never noticed any clutch slip, or oil smoke - where as now there's smoke just while sitting there idling..
Totally confused, hence I'm just gonna let it sit, and keep riding the bike (lets admit it, a BMW K100RT is pretty much larger than a mini anyway..) for a while until I feel like getting covered in grease and figuring it out..
Regards,
Damien
