By the looks of this thread, there is some haste on the how to I was going to have ready asap for ya all. Have been interstate on a few jobs, and home now, will get stuck into something for ya to read. As Mike said, 30mins read will just have you talking the talk, but its walking the walk that you really need, that takes time. IMHO I would give Paint supplies Sa a call and go in and see them, they have loads of paint going cheap. I just got nearly 12ltrs of asttd colours and at a great price also. I am going to be spraying Ed Met. Hot Green and will add my own pearls and ally paste till I get What I want.
Paint Supplies Sa has Glasurit going out for $15 /ltr, and then ou will want an ISO free 2pk Clear from em, it cost me $125 for a 3ltr pack including hardner. Ample for our mini's. Glasurit is what the Europeans are using for the BMW and Merc. PS, I should update the pics for Ed, he's comin on nicely, will be preeping for paint this weekend and next week. Yay for the holidays......
1970 mini K Posted: Tue Dec 19, 2006 7:06 am Post subject:
if your going 2pac use 2pac primer, if your going acrylic use acrylic primer. also make sure you use etch primer, the normal stuff is useless compared to it.
Not true.... Etch prime only if you are going bare metal. Autocryl or nearly any other HB pimer Will be fine. I only use 2pk primer if I want to get the job done asap and it also sands quicker from time of being sprayed.
slinkey inc Posted: Tue Dec 19, 2006 9:40 am Post subject:
I was warned about metallic being hard to do, so I didn't and I thought a mini being a 60s car doesn't really suit metallic but that's all personal opinion. If you don't paint metallic well doesn't it give lines and weird spots where all the metal bits go to?
Metalic like and mica paints are east to spray once you have a steady hand. Even strokes and criss-cross paterns are the way to spray mica paints. After every few minutes I swish the pot around to keep the mica well mixed so as not to let any settling occur. The aditive to be wary about is the candies and the met flakes in both powder form and liquid mix. I but all my pearls from Protec and is relatively cheap, I buy it in tubs which range from $35 - $70. Duo yellow/green is fun to try, especially overBlues and reds. Pearls can be added to your Acrylic, 2pack and all the clears. I find that adding to your base coat gives depth of colour, then a combination of met and duo pearl in a contrasting colour for the clear gives the wow factor. Red pearl over Green Base mixed with Gold pearl and duo grn/yellow will be what I am doing.
mad-mk1 Posted: Sun Dec 17, 2006 9:56 pm Post subject:
ifim corrct, painting 2 pac over acrylic will, burn and blister on the edges????
Only if using a cheap and nasty will this happen. Ed will have acrylic base coat specifically made for 2pk clear. There are many brands out there that have this system, try to stick with ISO free 2pk Clear, it will keep things healthy and in check.
The only time Acrylic will blister and shif on you like mike said is that if you have painted acrylic over 2pk without keying in the surface, ie rubbing the whole car down with at least 240 before your primer. I have seen people take shortcuts and spray base over original paint with Acryl and then wonder why they have got frying when 2 pack is sprayed over that. The answer is clear, When 2 pk hardens, it also shrinks to make a rock hard porous free surface, which if there is no sound base, will pull it out of whack. Presto, you have a custom fried effect, somehow not concours winning I'm afraid.
There is allot more work getting the bling out of a full gloss acrylic than there is in spraying 2pk.
My 2c worth.....
