Dark Fool - go the Mini! I wouldn't want to buy a modern "first car" - like Dr Mini said, the odds are that they won't have had the oil changed, or, like Mini Mad said, they might have leaked/burned all their oil out before the warning light came on. It might be fine now, but I wouldn't want to be the next owner of that car! Buy a Mini, check all your levels regularly, keep everything lubricated, fix whatever breaks (every car breaks occasionally), and enjoy the car.
It's like owning a pet - the extra work will help you appreciate what you've got, and set up good habits for the rest of your motoring life. The odds are that the previous owner will have cared for the Mini, whereas Japanese cars are showing that their reputation for mechanical infallibility is contributing to their downfall, from people who don't give them the (tiny) bit of attention they do need.
Or people who assume their mechanics give them the attention they need - which is fair enough, and the mechanic should, but "modern" mechanics can be like modern car owners, in that they don't always remember the way things used to be, and do the extra checks. Mechanics trained at dealerships nowadays just read the code and add the required fluid... Engine problems? Replace it under warranty... 20 years ago they would've fixed what you had, hopefully in a manner where the problem wouldn't occur again. What I've said is a bit general, no offence intended to those who are "modern mechanics". I'm sure there are good ones out there, it's just we can't be sure where you are!
