kiwiinwgtn,
What you have appears to be an OZ MK2 S crank. I'm not sure but I think this was also used in the UK MK3 S since all S engines and gearboxes were supplied from the UK.
When the OZ MK2 S was released one of the criticisms was that it didn't have the EN40B crank. It had the thick flange block and the 4 synchro box but no nitrided EN40B crank.
These were made from 12G1505A forgings, ie 1275 big journal crank forgings and ground to suit the S block main bearing widths, which are narrower than non S 1275 blocks, and the small journal big ends. The cranks were tuftrided, not nitrided because they are EN16 material which is not suitable for the nitriding process. EN40B is a steel suitable for nitriding.
Alternatively check the main bearing thrust washers and if they are 0.030" O/S?? then someone has reground a big journal crank to small journal size to fit the S. You need O/S thrusts to compensate for the wider main bearing width in non S 1275 blocks. If you bust an S crank this is probably the cheapest way to get a new crank.
In another BMC puzzle I think they used the same part no as the EN40B cranks, AEG 480/479. The 1 digit difference occurs in other areas of the BMC numbering system. Another example is the C-AEG 648 cam which appears as 648 or 649 depending on the publication or parts list.
The cross drilling was introduced at approx engine No9FSaY 42xxx. It only applies to the bigend journals and as the DOC says it was done to reduce oil starvation of the main bearings at high revs. Should be 2 holes at 90degrees to each other and the oilway drilling to the main journal should be plugged.
No idea what the GE622 number means.
Hope this helps
RonR
