It is currently Fri Aug 22, 2025 2:02 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Nov 26, 2007 9:13 pm
redrocketrider wrote:
whats a set of disks cost then?
A lot less than some insurance premiums and most hospital bills.
As Molly Meldrum would say, 'Do yourself a favour............'
Puts discs on!!
PostPosted: Mon Nov 26, 2007 9:39 pm
This space for rent
Puts discs on!!
I'll second that, the discs I fitted recently to my 1152 transform the car, it's much more confidence inspiring than the old maladjusted drums..
PostPosted: Tue Nov 27, 2007 2:16 am
:D  Front discs are a very good up grade!! especially if your putting in a hot "little" motor.......1 thing to remember with minis .....do not take any short cuts or it will bite you very quickly!! (its the $2 parts that let go too!!trust me i know this all to well and thats when it becomes expensive!! :( )  if you are gunna do the motor do as the Doc says.....get the crank crack tested then machined if required, another thing fit a double row timing chain, especially if you are going down the "stroker" route. ( :roll: ranting again) You also may as well do the gearbox coz 1 thing you dont want is the crap floating around the g/box going through your fresh engine and causing premature wear to your new bearings etc, or have it fail due to the fact of the extra grunt being put through it. Dont forget the parts inside it have just as much strain/stress as the engine and they both use the same fluid to lubricate. It may only need a bearing kit put through it and more than likely a layshaft and a couple of syncro's but get that done by some one who specialises in mini stuff if you have the experiance of working with them.anyways everyone has probably heard all this before so thats my 5 cents worth :D
 Post subject: 100cc
PostPosted: Tue Nov 27, 2007 5:06 pm
all the head work has been done,
fuel pump and carbi done,
radiator done.
starter motor and alternator done.
just needs rings and timing gear and chain,
so pistons and rings and bore and hone.
What about the crank, I bet it needs a regrind (~$120) and bearings, ~$100.
Why not grab an 1100 crank whilst you are at it :idea:
PostPosted: Fri Nov 30, 2007 11:39 pm
you forgot to mention banana peels in the diff! And an egg in the radiator to stop leaks.... probably should stop giving people bad idess it'll prob bite me in the ass....
Answer the Question....
BUT always Question the Answer
PostPosted: Sat Dec 01, 2007 10:10 am
[quote="redrocketrider"]such a tough choice,
I just wish i knew roughly how much to get the timing gear done and pistons and rings.
anyone got a rough idea?[/quote]
I went to mini king at Narrellan and just bought 1275 rings, bearings, gaskets, double row timing chain, bypass hose, and oil filter for about $220. The rings were $75 but I have seen pistons for only $200
Users browsing this forum: No registered users and 158 guests
