Mick wrote:
Who said:Bite of more than you can chew, and then chew like hell...I learnt more from my mistakes I made here (like correct thread types, bolt lengths, tension settings, good gasket practices, self machining and finishing (to reduce costs on a 2nd year apprentice wage of 142 per week in '91/'92), sanding, filing, bearing and seal insertion and removal, auto electrical, bagging and tagging, part numbers, material selection and spotting bodgy parts salesman.I learnt more than I ever did just thinking about it. Make a few mistakes and show the scars later on to your kids.Dive in and get used to cycling to work for a while. Nobody remembers a boring youth.
Tiny there is nothing to be unsure of if you bag, tag and take photos of all things that are removed. The bonus side is that you have a complete running car to start with so that makes it alot easier than what i started with. If there are people willing to be there to help or just to guide you while you are doing it, take them up on their offer as you will learn their "tricks" and you will in the future be able to assist someone in the same boat as you are in, in the future. Dont listen to people who have negative opinions towards your plans but dont forget to put a realistic time frame for this "build" and stick to it 100%Mine (the first time) took me 6 months and it was a stripped out, quite bent, rolling shell (structure was fine panels bent) with a siezed 850 engine missing the head etc......panel, paint, sorce and build new engine and g/box, get all the bits for the interior, wheels, tyres, brakes etc, etc...its no show pony and it WAS built to be driven (not just washed and hidden) every day so perfection wasnt an issue. my wifes one was similar but the body was half stripped of paint, the mice had been at the wiring and the l/h/side of the body (inc door) was full of bog there was an engine in bits that had had all the machine work done and required assembly the g/box was done and assembled (with good bits inside) etc, etc...... anyways from what it was to what it is now is a huge difference and is in the same boat as mine ....built to be driven....not a show pony .... but the colour makes it sure stands out!
Oh and hers only took 8 weeks to build........yes i had a day job back then working on f#@&ing french cars!!
I say go for it, dont be shy or you will never learn anything
