It is currently Fri Aug 08, 2025 3:47 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Mar 25, 2008 8:04 pm
ausmini mod
ausmini mod
mattsmadmini wrote:
where abouts do you find these types of paints? is there a cheaper aussie made version thats easy to buy?
Matt, ping me in MSN tomorrow, I should be able to find the details of a place near my place, they stock POR15 and other goodies... unless some of the lads can remember tonight.
Peter.
PostPosted: Tue Mar 25, 2008 8:06 pm
I used POR15 on my underside, but due to the surface prep I had problems with area's flaking. So i wire-wheeled it all back and used Gravitex under body coating. I just etch-primed and sprayed it on.
I got it through a local bloke that does metal fabrication (also building his own hot-rod). Its made by U-pol and it uses a special spray gun attachment. We also found it goes on much better when thinned down.
A quick Google shows it on this website:
http://www.platinumpaints.com.au/
PostPosted: Tue Mar 25, 2008 8:12 pm
www.por15.com.au
Use the Marine clean and metal ready.
Can be brushed or sprayed and its a good self leveler when brushed
or even www.vgautopaints.com.au
Also:
http://www.ppc.au.com/wherensw.htm
Shows where to get POR15. Keep in mind I believe it was the prep process that stuffed up my POR15 experience. I still believe it was a great solid product, but I ended up with too much zinc phosphate crap that just wouldn't wash off, so I painted it anyway, low and behold it didn't stick.
PostPosted: Tue Mar 25, 2008 8:16 pm
Milatsmadmini
cheers guys :)
