It is currently Sat Jul 19, 2025 10:04 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Feb 10, 2005 8:16 pm
I modified my lights by removing the single filament fitting and putting a double filament fitting used for the brake/park lights from a couple of old assemblies I had lying around.
Just bend up the tabs to remove and push them down flat again when you instal though I did add a drop of aradite to make sure it would move.
I'm not sure if the fittings from a clubbie will fit,you may need to use the ones from a round nose.
PostPosted: Thu Feb 10, 2005 9:23 pm
I reckon put a 5" Hella foglight on the boot and fit a bloody dash switch.. 8)
Basic and it works. Also can be used to get revenge on driver following with high beam on. If any one fits a manually operated reverse light it must have an internal warning light for when it is switched on.
Chris
Everything I like is either
PostPosted: Sat Feb 12, 2005 6:25 am
Or a big spotty...Yer I know its illegal but I was spotted by a truck driver once when he thought I was to close to his arse :roll:
PostPosted: Wed Feb 16, 2005 9:19 am
Sorry for the delay in getting back.
Thanks to all of the advice, it has been very helpful!
I have a couple of old tail lights with broken indicator plugs, so i think I'll have a play with these first (junk anyways). If I don't have any joy then the 'fog' light on the boot will be my next choice.
Any know the rules for adding one in QLD (max wattage etc)??
Matt
Users browsing this forum: 748rum, Aussie Brian and 96 guests
