It is currently Fri Aug 01, 2025 1:19 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Feb 28, 2009 9:49 am
a reliable second car should be everybodies toolkit
PostPosted: Sat Feb 28, 2009 10:27 am
Slow-Po
Over 10,000 posts and he finally comes up with one that makes good sense. :)
PostPosted: Sat Feb 28, 2009 10:32 am
But it came from the man who had a V12 Jag as his "reliable second car"
PostPosted: Sat Feb 28, 2009 10:55 am
i've found an unreliable second car to be ok so long as it's only unreliable when the mini isn't.. works so far!
tim
PostPosted: Sat Feb 28, 2009 11:04 am
Slow-Po
Ouch, kick him him where it hurts. :lol:
PostPosted: Sat Feb 28, 2009 12:38 pm
First on Your List
A Trolley Jack and Axle Stands
"Do Not get under your car unless you use Axle Stands"
Multi Metrer
a Piece of Garden Hose with the Empty can in the Boot and you may as well have a two Liter bottel of water also
a Deep 3/4 Socket (I use T&E Sockets and have not broken one yet) for wheel Nuts and a length of steal tube to go over the handle
Twist Lock Wire wheel for the Grinder for rust locating
Magnet for finding Bock in the Body
Bag of Rags you will be amazed how often you will use them
WD40, Degreaser & Carby Cleaner
Wire Ties Great for holding everything except exhaust
& Ausmini :wink:
PostPosted: Sat Feb 28, 2009 12:57 pm
is was reliable - it worked perfectly well when it was running :P - except for that Christmas day when the it left us stranded with all the family and presents :roll:
PostPosted: Sat Feb 28, 2009 12:59 pm
Santa didn't Cum :shock: blame the Cat :wink:
PostPosted: Sat Feb 28, 2009 2:44 pm
Slow-Po
When you are depending on Cityrail to save Christmas, it is indeed time to buy a new car. :)
PostPosted: Sat Feb 28, 2009 6:03 pm
It's all very well to carry spare smoke but how do you get it back into the wire.
Apart from that, great thread
Hopefully the front end always goes first. Rob
PostPosted: Sat Feb 28, 2009 8:33 pm
Trolley jack.
Essential equipment for checking the strength of the floor pan or condition of engine mounts when raising the car using the gearbox casing as a jacking point................ :roll:
