It is currently Fri Jul 18, 2025 5:12 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Mar 08, 2005 5:04 pm
i currently have 3 fingers on the front and 4 on the back space between the arch and the wheel/
PostPosted: Mon Mar 28, 2005 9:13 pm
Okay so I'm up for some Koni shocks... where do you guys get them from?
dewey
dwightgunning.com
PostPosted: Tue Mar 29, 2005 4:33 pm
Kev,
when i got my brake last year when i went to UK i bought 4 GAZ adjustable shock, i have not doen heaps of miles as yet but so far with the amount of adjustment i have and the difference it has made i could not be happier.
100% Pure A Series Turbo
PostPosted: Tue Mar 29, 2005 4:36 pm
Interesting Bottom Are you have :shock:
PostPosted: Tue Mar 29, 2005 5:11 pm
These are the shocks that i have got for the van..
I got a mechanic across the road from my work to
get them, dont know where he got them from but he
said that Koni wernt sending or getting any more here
in AUS??? That is what i was told anyways..
And the van is sitting very high at the moment so i also
am in need of a set of hi - los, and does anyone know where to
get a cheap set from?
Daniel
Life's a garden.... Dig It!
PostPosted: Tue Mar 29, 2005 8:03 pm
[quote="Gordo"]These are the shocks that i have got for the van..
Daniel
I rang the importer (Proven Products, Albury NSW) and got the same story. Spax prices were off the planet so I got KYB. I noticed that Mini Mania has got rear Konis for Vans on special at the moment. I don't know if they are adjustable though.
Your height problem if it is excessive could be due to using sedan trumpets as they are longer.
Chris
Everything I like is either
PostPosted: Tue Mar 29, 2005 9:54 pm
Chris wrote:
My error here. They are adjustable Spax, see here. Good Price though.
http://www.minimania.com/web/Item/158%2 ... Detail.cfm
Chris
PostPosted: Wed Mar 30, 2005 4:47 pm
okie dokie :)
Ordered my Koni adjustable "Sport" shocks today $270 set fronts, $270 set rear clubman van from Wilkinson Suspension, Perth, WA
Ordered my "Heavy Duty" HiLos from Mincraft (Bayswater, WA Ph 9370 2882) yesterday (here tomorrow)
HD $58something ea plus 2nd hand rear extension bars $10ea $254 the lot.
"Standard" HiLos are $51something ea, don't ask me what the difference is :roll:
Hopefully that will give me some negative camber (lowering) so the wheels dont stick outside the flairs quite as much :) oh and it will handle better ;)
Can I put them in myself? Shockies and HiLos? Any special tools required?
78 van 1300 cam extractors weber, 12" Superlights Metros Konis HiLos MP3 Amp Sub Alpine speakers and lots of fur
www.crazybitchracing.com
PostPosted: Wed Mar 30, 2005 8:33 pm
You made the plundge I will be interested how you feel with the Koni's Is I'm useing the orginal untill will allow for them..More important things first :roll: Motor and Brakes
jill200sx wrote:
okie dokie :)
Heavy Duty Hi-lo's never Heard o fthem :?: Get a Pickture of them before they go in :shock: I just cant see the reason :idea:
Shockies and Hi Lo's are can be done at home but you may need a Cone Compressor for the front
Whats a HS and Rear extension Bars :?
PostPosted: Thu Mar 31, 2005 7:23 pm
they said Heavy Duties are "stronger" for a difference of around $7 why bother with standard but. :roll:
This is them with 2nd hand rear extension bars
Can I use something other than a "Cone Compressor" to get the fronts out?
PostPosted: Thu Mar 31, 2005 7:28 pm
You can dismantle the top arm. :roll: Personally I'd bludge use of a compressor, but if the threads in the donut rubbers are stuffed you won't have a choice.
PostPosted: Fri Apr 01, 2005 8:48 am
I also need to get the old cones out.. Took a look yesterday and
without the compressor tool i dont think its gonna be real easy..
But apart from that the ride afterwards should be pretty sweet,
just need a motor and gear box in there so i dont have to flinstone
it everywhere..
PostPosted: Fri Apr 01, 2005 10:03 am
i have the suspension on my car out and am putting in hi lo's too. do i need to knock the ball out of the old trumpet and put it in the hilos?
Aaron
PostPosted: Fri Apr 01, 2005 10:06 am
Aaron
Yes unless you buy new ones... I would fit new ones complete, unless they are new. :wink:
PostPosted: Fri Apr 01, 2005 5:59 pm
Buy new Knuckles..pieace of mind and only $30 for a pair
Fitting a set of Hi lo's without a compressor....Jack car up by the sub fram and axle stands, Undo Everthing regarding to the top arm and the Rubber stop under the same arm (you may need to replace it) you may need to fiddle with a jack to get it out
Jan..I don't see how they are Heavy Duty....I'm Questioning if normal Nuckle wil fit..They look similar to mine from Minispares and they required a sleave to fit :?
