1071 wrote:
I suppose I should worry that after 17 years my cam must be getting ready to chuck it in.
A few years ago I was the logistics manager for the Army's heavy vehicle fleet. One of the resources available was DSTOs material research lab. In the view of their lubrication expert, synthetics provide inherently more protection as they don't rely in any great degree on additive packages.
A couple of times I've been tempted to save money and used normal oil. The change in the level of debris on the magnetic plug has always driven me straight back to a synthetic. I used to use 5W60 Shell Helix but that seems to have disappeared. Edge 10W60 seems to be as close as you can get these days.
You pays your money and takes your chances.....
Cheers, Ian
im guessing this is some sort of pay out to what GR was just clearing up for everyone?
dont get me wrong synthetic oils are great for the modern aged vehicle.. but i cant help to find that doesnt matter who you speak to, they all say the same sorta thing whether is be a car lover or mechanic... dont run synthetic oils in your classic car!...
main reason for what GR was just saying about the synthetics not sticking and possibly causing premature wear.. unfortunately every engine is different therefore will react differently..
i think the bottom line to this thread is... use the oil you feel more comfortable with. if you believe the experience of the wise is right then follow the advice given.. BUT if you feel that modern technology in oil will improve the life of your mini/car.. then use it..
but if your engine fails on any count due to oil cause problem... DONT come here to sook..
