It is currently Thu Aug 07, 2025 5:49 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Nov 11, 2009 1:40 am
cush wrote:
Something like this would be rather cool though. :)
But then you still have the wheel arches as big holes there.
Hmmm... You could close them though. And lower them into the body. And add some spoilers. Each side. And on the rear. And make the body all flat & streamlined. And add an inline engine to allow a narrower frontal area. And add a supercharger. And...
:P :lol:
The Swiss Mini Racing Team (which is now 'banned' by new regulations :twisted: ) used similar setups wiht succes on the Nürburgring 24h endurance race (rear diffusor & 'flat' floor).
http://www.zonewicz-faserverbundtechnik ... treff.html
http://www.lotushouse.de/rover/24h-renn ... index.html
http://www.miniweb.ch/smirt/doc2008/smi ... ffusor.jpg
PostPosted: Wed Nov 11, 2009 5:31 am
you can reduce the form drag by careful application of that wonderproduct - duct tape.
or you can deseam it - that might be good for 1mph. or just knock them flat with a hammer.
replace handles with clubbie doorhandles, delete external mirrors, wipers, fuel tank inlet, basically anything that sticks up/out.
cheesecutter tyres will reduce frontal area.
michael
PostPosted: Wed Nov 11, 2009 7:35 am
Asphalt wrote:
Now THAT'S less than subtle.
But good to see it works
PostPosted: Wed Nov 11, 2009 8:28 am
Well I guess it's a tad more subtle than this one:
:lol:
PostPosted: Wed Nov 11, 2009 8:51 am
:shock: Hang on. weren't we trying to REDUCE the drag??!!! :lol: :P
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Wed Nov 11, 2009 12:29 pm
The lower your car to the ground, the less air goes under it, which develops disturbance.
Enclose your wheelarches closer to the wheels. Fit skinny wheels and tyres. Pump em up to 40psi. Flatten the underbody. Deseam it.
Square-up the rear corners of the bodywork. Front air dam right down to the ground. Lower sills to the same height. Block off your grille intakes.
It all works.
PostPosted: Wed Nov 11, 2009 12:44 pm
Tomboss Breweros
7 and 8 port heads are good cos they remove air from the front and put it at the rear, creating a pressure imbalance that wants to move the car forwards, the more air your engine moves the faster you go :wink:
Large diam pipes from front to rear so instead of your car going through the air, the air goes through your car :roll:
Finally, really hot running lights, they heat up the air in front making it less dense and easier for the car to go through :lol:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Nov 11, 2009 2:11 pm
Here's some more ideas:
http://jalopnik.com/photogallery/b16mini/1001328904
and from a similar thread (scroll down):
http://www.theminiforum.com/forums/lofiversion/index.php/t99248.html
Back to the original question: Z-Cars quote the Monte Carlo as having a top speed of 153mph!
http://www.zcars.org.uk/montecarlo/index.htm
-James.
Users browsing this forum: Bing [Bot] and 93 guests
