rathcoole wrote:
Thanks PK,
I bought the filter and stub stack from Keith as a kit, its not listed now on his web site, only the ultimate filtration kit for twin 1.5 and 1.75, The stub stack is listed on its own. Email Keith, he should be able to supply the kit still, otherwise, just grab the stub stack and get the filter from ITG. For a HIF44, the base plate is 16JC20 and the filter is JC20/25 I'm pretty sure.
It works very well with about the same clearance issues as with a cone K&N. I run a right angle drive off the back of the speedo so the cable doesn't rub its way through the filter element the way it started to on the K&N's I have run.
Kevin
Thanks
