It is currently Fri Jul 18, 2025 11:19 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Apr 15, 2005 12:02 pm
meeni wrote:
thats pretty good,!!!!! :shock: do they have the same remote shifter size as minis or would a new gearbox be the go, and do they have the same driveshaft couplings at the differential end??? if so i will go and get one asap!!!
Forget the 1100S box- it's only a 3 synchro, and the ratios are crap for a Mini. :x
I'm using a Mk2 S box, with 3.64 diff now. :wink:
PostPosted: Fri Apr 15, 2005 12:06 pm
Flying Brick wrote:
I'm probaly getting off the track for this thread, but drmini, did you use an 1100S head on the auto block or a 1275 head and drill another stud hole in the block.
Steve.
I'm running a Mk2 S head with bigger valves, the block has been drilled & tapped for the S rear stud and front bolt. They are worth having. 8)
1100S head (and the 1275LS head, 12G1316) can be drilled out for the extra holes. The head casting has metal there for this.
Users browsing this forum: Bing [Bot] and 103 guests
