As already mentioned, the fuel lines do get hard with age and the extra heat of the air-cooled engine bay. Then they split without warning. The solution is to use quality fuel hose. Not cheap stuff from super-crap.
The brass fittings do come adrift from the carb and fuel pump, but it's usually because some well-meaning mechanic has put a fuel filter in the line between the pump and carb. The weight of the filter vibrating around pulls the brass fitting out and fuel pumps directly on the distributor. Spark+Fuel=Woosh! The solution is to fit a filter between the tank and the pump, if you must have one.
The other main reason Beetles burn is pillocks leaving the battery cover off and then putting weight on the rear seat which shorts out the springs on the battery.
My own Beetle is a late Superbug so it has a Macpherson Strut front end and proper IRS. No swing axles here.
