So, the kit is now installed and Barney has fully adjustable suspension. I have a couple of questions now. To reduce the horrific toe-out on the front, the old man decided we should slacken off the steering to push the front of the wheel in (if that makes sense). Barney looked like Dumbo at one point! Even with the adjustable tie rods at their shortest we could not get the toe-out in to an acceptable level.
So NOW I've got a feeling that the adjustment to the steering rod may have created some sort of 'slack' in the steering. I've found a quiet, open bit of road near the coal loaders here and given it a bit of a swerve test and all seems to be OK, but on the open road (and at higher speed) it feels like the car wants to swap ends. Particularly on right hand bends there seems to be normal turn in and then if I try and pull on a bit more lock it seems to steer 'quickly', in doing so it loads up the rear and everything feels like it wants to switch ends. It feels like it sort of moves around in the steering when you apply lock and then suddenly finds a direction. Awful descriptions I know.
So the real question is, should there have been a need to play with the steering in initial setup and in doing so have we created a steering problem.
Before I noticed this I headed over to Simpson's for a wheel alignment. Any suggestions to setup below? I'm chasing a 'fast' road setup, with the occasional track day (oz50!).
