Hi Austin 850
Please don't listen to any one on here on how to set the RE83 cam up as you will only go backwards, i designed and tested it and thats where it works best and you will loose top end performance if you retard it.
GT MOWOG why would you put a 140 wade cam in a in a daily driver? to start with that cam will make peak torque at 5500rpm (295 duration)i don,t run that much duration in my race car, and will make peak power at 7500 rpm .
One reason i don't give out timing figures is because it realy does confuse people when trying to get the same timing figures on each valve with the mini rockers,GO READ MY ARTICLE SMALL BORE PROJECT and you will see what i mean, setting up the cam using the full lift figure is more accurate,
Your wade 104 cam is a very lazy cam for that duration 270 and 212 @ .050, a std mk 1 cooper s cam with with 240 dur has 212 @ .050.
My RE 83 cam ( just to keep you and your friends happy)has these figures
duration 260
Valve timing IN OP 20 deg btdc closes 60 deg abdc
EX op 60 deg bbdc closes 20 deg atdc
Cam Lift .270
Lift @tdc .o83 in and ex
DURATION @ .050 234
But that tells you very little about this cam
And just for the record the RE13 with .020 tappet settings has 268 duration and 236 @ .050 lift
Graham Russell
