gr4h4m wrote:
Nice car, At what PSI are you injecting the water? Is it just water or meth too? I've just installed a water injection kit onto my sc12 setup and its off the rolling road on the 2nd for the setup, so any experiences would be gratefully received.
Given that the SC12 is on a 998, it can make some pretty high pressures in short bursts. . .I've seen up to 16psi on the guage.
I've set the water injection to swich on at 5psi via a pressure switch fitted to the manifold. . .any lower than this and the engine bogs down badly.
I've tried straight methanol, a 50:50 water/methanol blend and straight water. . .I couldn't feel any great difference between them, so I've just stuck with water. Given that I primarily fitted the water injection for cooling (not necessarily for performance) then straight water
should do a better job in any case. . .
My water injection system is reasonably crude but it seems to be effective - I've used a late model VW Golf windscreen washer pump (capable of 40psi) connected via nylon tubing to an atomising nozzle (which, from memory delivered 70ml/min water at 40psi) that is positioned to fire directly into the supercharger rotors. One thing I do need to fit is some sort of check valve or solenoid or something - off boost, engine vacuum is enough to pull water through the pump and into the manifold wich can cause water to sit in the manifold or (presumably) in the chambers whan the motor is switched off. Probably not a good thing.
Without the water switched on, the car will start to ping badly at about 8psi boost (98 oct fuel). After an extended period of running, the main manifold it pretty much too hot to touch. With the water on (switched at 5psi) I cant get any detonation under any type of driving, even right up to 16psi (momentarily). After a decent run, the manifold is only warm to the touch.
You should probably take all my 'test work' with a grain of salt in any case at it's all been done by plug cuts and seat-of-the-pants testing - I haven't had the car near a dyno for tuning purposes. I know the car does run lean at the top end but i haven't had time to sort it out yet. I have a 1380 waiting in the wings to go in the car, so I probably wont do much more work with the 998 in any case.
