It is currently Mon Jul 28, 2025 5:24 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Jun 03, 2011 8:46 pm
Potato potato :wink:
jme wrote:
I want to upgrade from front drums to disks, probably 7.5" Is a booster required?
66S wrote:
The servo (booster) will not necessarily improve the brakes but it will decrease required pedal pressure which could improve stopping distances.
l
Depending on the vehicle it may very hard or even impossible to lock the brakes without a booster.
...and there's more. My point was (poorly made apparently) that the original poster could take it from some of these comments that a booster will reduce his stopping distance, and it is a 99.9999% certainty that this is not the case.
PostPosted: Fri Jun 03, 2011 8:52 pm
l
The booster will not increase braking performance, only reduce pedal effort. Even in the earlier example I gave, if the steering wheel was stong enough to resist being wrapped around your ears and your foot was heavy enough (it usually is on the other pedal), then you could get a truck to stop without a booster. There is a maximum required effort that is allowable by the powers to be, that's why when you go for a roadworthy, it's not just what is happening at the wheels that is measured during a brake test, but also the pedal pressure.
PostPosted: Fri Jun 03, 2011 9:42 pm
"I want to upgrade from front drums to disks, probably 7.5" Is a booster required?"
Required??? By who???
By Rego? - go ask them.
By performance? - many Grp N guys don't use them. With road pads/tyres you can lock the brakes without one - you can't stop faster (as long as you ease off before locking occurs :)
By preference? Definitely booster - although many would not agree.
Cheers, Ian
PostPosted: Fri Jun 03, 2011 11:28 pm
90% of proper modern racing cars dont use them, its all in the master cylinders as to how much effort is required.. but anyway, i prefer not using one, its very easy in a sticky situation to "jam" the brakes on as hard as you can, hence why abs is so handy to the modern retarded driver.. the non boosted brakes give you a much greater pressure window to operate them in meaning you can be super precise and really feel what the brakes are doing under your foot, its really easy to unlock a locked brake without a booster but its a freaking nightmare to do in a boosted car. there is no stopping distance decrease.. they stop the same, its your leg that has to change to operate them to their maximum potential. anyway, i guess it depends on how you feel in a car, are you capable of hitting the pedal hard enough to stop it if need be, if not, your probably 95 years old and need a booster :wink:
ps, to stop clowns, i am talking about minis, with mini brakes and mini master cylinders.. i dont care about old sh!t trucks
PostPosted: Sat Jun 04, 2011 6:44 am
Hmmm, I think I'll give up on this one. It seems to me that JME would have got his answer out of the advice that has been given. At least, I hope so.
Regards
Al
(Who is involved with compliancing every work day)
PostPosted: Sat Jun 04, 2011 8:59 am
Just an interesting observation....My MG weighs about 800 kilo and comes
standard with unboosted 8" discs. In the dry they're quite good, you've just
got to get on them heavy. However in the wet it is very difficult to determine
the point of lock up. A very uneasy feeling.....dangerous in fact.
It could be the pads although I'm tending towards the thought that the extra pedal pressure
required along with skinny tyres makes it difficult to judge the lock up point.
So even though it will make the engine bay look messy. I think I will fit a booster one day.
PostPosted: Sat Jun 04, 2011 9:46 am
Try a set of different grippier pads first, something like the EBC Greenstuff pads. That might reduce pedal pressures a bit.
PostPosted: Sat Jun 04, 2011 11:59 am
Hmmm - that's exactly the opposite of what I think. I've always thought that unassisted brakes are better for determining the point of lock-up, because it's just dependent on your foot pressure alone. I've always though along the lines of meeni:
I suppose it just goes to show it's all about preference.
Having said this, if you're looking at boosting your brakes, it may be worth reconditioning them first. I was thinking of boosting the brakes on my all-round drums mini, but after replacing the MC, reconditioning the bias valve and adjusting it all as good as I can get it, I wouldn't bother.
I've locked the wheels up with A008s (at a roundabout, avoiding a bini that pulled out infront of me :) and I'm not sure I could have before reconditoning them. That's another thing I like about unboosted brakes - you can only ever lock them up if you really mean business.
PostPosted: Sat Jun 04, 2011 8:32 pm
I prefer no booster
I would rather the wheels to not lock up easy cause once they have locked
once good luck getting them to not lock up again while you are trying to pull the car up quickly with a booster
PostPosted: Tue Jun 24, 2014 7:32 pm
just bumping this up -
Running 7.9" vented discs on the front with drums rear - single line.
Car had a booster , keen to get rid of it due to lack of space - really not too bad ?
PostPosted: Tue Jun 24, 2014 7:47 pm
I was a `no booster man' with S discs for 20 years, until last year. Then, I put a recond VH44J on because it was sitting here on the shelf.
Now, I would not be without it, it feels and stops like a modern car.
I put it under the dash, where it's out of the way.
PostPosted: Tue Jun 24, 2014 7:56 pm
Use a booster on a street car, it feels much better.
It will work without though, just a bit heavier to push. Here is one I prepared earlier...160km/hr, STD Cooper S discs, STD Bendix pads and no booster....on a racetrack
http://m.youtube.com/watch?v=NVdILEM7bZs
Dan
PostPosted: Tue Jun 24, 2014 8:13 pm
So if I remove a booster from a factory fitted Cooper S, its illegal. But if I take the 7.5 inch disc brake setup off that Cooper S and fit it to an 850 without the booster it is legal?
PostPosted: Tue Jun 24, 2014 8:16 pm
I have a Leyland Clubman 1977 that came fitted with drums all round.I have fitted 7.5 discs without a booster, and brakes are fine for me. It has a tandem master cylinder, so if I wanted to fit a booster, do i connect it to the front brakes only?
PostPosted: Tue Jun 24, 2014 9:10 pm
That is the usual, easiest way.
The rear brake limiter locks at about 450psi anyway, and the wheel cylinders are 5/8", = the rear brakes do bugger all under hard braking.
Users browsing this forum: No registered users and 68 guests
