slide wrote:
Wasn't the breather on top of the flywheel/clutch housing put there to relieve pressure on the primary gear seal? If you block it off does this increase the pressure?
No it was put there because 1100S etc motors have no sideplates.
Crankcase pressure there is same as elsewhere in the sump.
It's not a great spot for a breather, because oil gets chucked up it at high rpm on LH bends.
Like at the dogleg at Wakefield Pk, my car made like JB007 for 50M after.
