It is currently Sat Jul 19, 2025 8:53 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Aug 25, 2012 8:51 pm
1380 K wrote:
So remove the head,Measure the compression chambers and the piston dish and work out the compression ratio ? Thats my first step? then modify if the ratio is too high?
Corrrrect :)
So you need to, Measure your combustion chamber and note the volume... we'll call that "Comb V"
Piston dish we'll call "Pd"
Compressed Gasket Volume "CGV
And the volume for the Crown to the Deck "CD"
and we'll do it the dodgy fitter (just stirring :) ) way and skip the ring land to crown, because you would physically need to measure the piston crown diameter and the bore size, then the distance from the top edge of the ring land to the crown then work out the volume....
So to help you out, the gasket volumes are ..
3.8cc for a copper gasket
4cc for a BK450
4cc for an Aluminium compsite gasket...
So, once you measure the volume of the combustion chamber, and piston dish... we'll go -->
Comb V + Pd+ CGV+ CD = Combustion space
(note that size)
Then add that to 345 (swept vol of 1 cylinder) and devide the answer by the combustion space
That will give you your compression ratio :)
Clear as mud? :)
[EDIT] Woop, doc beat me too it :) [/EDIT]
Users browsing this forum: No registered users and 72 guests
