It is currently Sun Jul 20, 2025 3:45 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Jan 31, 2013 12:09 pm
Yeah apparently they all have them in there except the tin type "Cooper S" master cylinder. I've run it like so since forever and there is plenty of meat still left on the Black Stuff pads and rotors... so not sure if is a big deal?
PostPosted: Thu Jan 31, 2013 1:04 pm
IMO there would be more Minis running around now with front discs and the restrictor valve still in the MC.
These things are not a check valve, they just restrict the return flow a bit.
If you can wiggle the pads in the caliper, there is no problem leaving it in. :wink:
PostPosted: Thu Jan 31, 2013 2:38 pm
slow return valve... it`s there for your drum brakes ... they are still on the rear of the car
without the valve you won`t be able to "Pump-up" a brake pedal when your shoes run low & are in need of adjustment
PostPosted: Thu Jan 31, 2013 3:41 pm
Leaving it alone sounds great to me :lol:
Really appreciate the info from all!
Enjoy the fun Zulu!
1975 Clubman
1152cc, 40dcoe weber, RE83 cam, GRed head.
