It is currently Mon Aug 04, 2025 5:11 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Feb 08, 2013 3:48 pm
Holden red sixes you don't use oil, you use sealant because some of the bolts screw into the water jacket.I.
GM head stud thread sealant is both a sealant and lubricant.
Al
PostPosted: Fri Feb 08, 2013 4:52 pm
sitnlo62 wrote:
michaelb wrote:
Probably irrelevant for this item :? But when I fitted my new ARP head studs for 1275 I recently built, the ARP kit came with a little sachet of grease and instructions to hand tighten the studs into the block :shock:
Hand tightening Studs is the correct procedure for any stud.
When you think about it, tightening a stud into a threaded hole achieves nothing..
A stud that has been driven into its mating thread by a spanner, stud driver or the like has in fact not been tightened at all, it has been screwed into its mating thread until the threads are Jammed together. Not a Good Situation.
Dave
I leave my studs finger tight in the block. So whenever I need to get the head off I don't need to disturb the *&$#@( LCB and zorst. I just pull all the head studs then slide the head forward and up.
PostPosted: Fri Feb 08, 2013 7:59 pm
I attached the head back on and none of the studs snapped. YAY!
Does anyone know what the valve clearances are now? i have installed 1:3 roller tip rockers.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Fri Feb 08, 2013 8:01 pm
Set to .016" if you don't know what cam it is.
And when using feeler gauges on roller rockers stick them in sideways so you can feel if tight or not. Not in the front....
PostPosted: Fri Feb 08, 2013 8:18 pm
arp are the best , they dont stretch ot twist , u will rip the threads out of the block before you snap a 8mm bolt
PostPosted: Fri Feb 08, 2013 8:21 pm
I'd rather snap the bolt! :lol:
PostPosted: Fri Feb 08, 2013 9:40 pm
Hopefully they stretch slightly. Wouldn't be much use if they didnt.
